knock and p0172 code Help
Old Dec 26, 2011 | 03:44 PM
Heezayx's Avatar
Question knock and p0172 code Help
Okay so heres the deal... 90% of the time i hit boost my SES light flashes and i feel a dramatic loss in power. now since my SES flashes that means im picking up knock and so i have been babying my evo so i dont have detonation. anyways i just scanned for codes and im picking up a p0172 code meaning im running too rich? could this be related to my SES light flashing?
i am going to conduct a boost leak test and see what i can find.
also, ive been getting terrible gas milage about 8 miles to the gallon and that is mostly daily driving
im thinking running to rich and bad gas milage has somehting to do with my o2 sensor?
anyone have any input help ?
Old Dec 26, 2011 | 03:49 PM
dahuii77's Avatar
im on the same boat bro??..hit boost and service light starts coming?..knock i know for sure!!..but i got a big boost leak coming from my manifold so i hope that will fix my problem??..
Old Dec 27, 2011 | 01:43 AM
Heezayx's Avatar
im 99% sure this is all from a boost leak, since the leak is after the MAF sensor its causing the engine to run rich because the proper fuel ratio is being injected into the system based on the MAF sensor but the air is leaking out..... so its overfueling itself
Old Dec 28, 2011 | 08:18 PM
Heezayx's Avatar
yep it was a huge boost leak.... my charge pipe gasket was half missing and my bolt was loose
changed it and fixed the whole problem evo runs alot better now
Old Jul 27, 2012 | 03:19 PM
connor4200's Avatar
i dont get the ses light flashing but i throw the P0172 when just cruisin i hold boost fine under WOT and i get detonation when tryin to take off now as well and my idle fluctuates from 500-1000rpm some times, any idea??
Old Jul 30, 2012 | 11:02 PM
Heezayx's Avatar
do a boost leak test.... sounds like a leak
Old Jul 30, 2012 | 11:09 PM
dcix631E's Avatar
same here..been using my evo as dd. im getting knock and boost leak.i suggest find out what rpm your getting most knock on and have boost leak check
Old Jul 31, 2012 | 01:47 PM
connor4200's Avatar
on evoscan im guessing but i hold 25psi till around 6500rpm and it tapers to 19psi at redline. I get full boost at 3500-4000rpm. redline is at 7800
could thaat be a dv prob aswell? and ill be doing a leak test as soon as i get my hands on compressor
Old Jul 31, 2012 | 01:48 PM
connor4200's Avatar
ive been usiing mine as a DD aswell.....
Old Mar 16, 2014 | 07:31 AM
sbannister14's Avatar
I'm having the same issue with my evo. Did u guys ever come up with a solution to fix it?
tarheelsoldier
Mar 22, 2015 08:54 AM
kr1s
May 27, 2014 12:28 PM
spyder526
Jul 28, 2012 07:37 PM
evillancer06
Dec 21, 2009 07:14 AM
spooch
12
Feb 11, 2008 07:54 PM
