Rear diff leaking?
Old Dec 27, 2011 | 08:08 AM
Dherch17's Avatar
Rear diff leaking?
Hey guys,
I have a 05 EVO 8. Anyways recently I noticed when i put the car up on the lift on the rear diff there is a leak coming from the top...it's not from where the gasket is but almost like its coming from the top of where the axles go into the diff. However I don't believe this to be the case based on my observation. I checked the level of the diff fluid and it is right where it should be... So I guess what I'm asking is there a vent that fluid will come from if it's over filled? Because shortly before I bought the car it was serviced at the dealership and I'm wondering if they over filled it. Any help would be much appreciated.
Old Dec 27, 2011 | 11:28 AM
todd6027's Avatar
yes id agree with the overfill theres a vent in the top of the cover
Old Dec 27, 2011 | 02:45 PM
barneyb's Avatar
There is a vent on each of the gear boxes, transmission, transfer case and rear differential. The vents allow air pressure created when the gear boxes are hot to escape. Otherwise, the air pressure might force lubricant out through seals.
Vents shouldn't leak lubricant. If the vent is the source it might be reason for replacement.
Old Dec 28, 2011 | 09:00 AM
Dherch17's Avatar
Ok well the leak seams to be coming from the top so what else could it be coming from? Are you positive the vent doesn't act as a safeguard to overfill? And could overfill cause so much pressure that pushes it out the seals?
Old Dec 28, 2011 | 10:01 AM
barneyb's Avatar
Well, you say you just had it serviced so maybe they squirted oil all over it. My wife's car, when we were first married, made a puddle of oil on our garage floor. Three months later it stopped dripping. The answer - the place where she was having it serviced put some oil in the engine and some on the engine and this was at a dealership. Get a can of degreaser spray, clean the case and see of the leak reappears.
BTW, you also say the differential is not overfull.
Old Dec 28, 2011 | 10:06 AM
Dherch17's Avatar
Well usually when I wiped it off it would come back. However right before I left for Florida two weeks ago I cleaned it off real good took it to summit racing about a 40 min round trip drive came home and didn't see any leaking but then I left shortly after so I come home tomorrow and I'm gonna see if it's leaking again so I'm crossing my fingers!! Hoping now the level of oil is correct and before it was just overfilled. It's just funny cuz a stream runs down from the top and is identical on both sides which is weird to me...
Old Dec 28, 2011 | 05:24 PM
barneyb's Avatar
The vent, as I remember, is on the rear cover at the top, if that is any help. These vents are rubber and are installed with sealer. I knocked the one on the transfer case hard enough to break the seal and then it started leaking. I wasn't sure what was happening so I bought a new vent and installed it with RTV. No more leak.
Old Dec 28, 2011 | 05:51 PM
Dherch17's Avatar
The only thing I can feel at the top is a rubber nipple that feels like a moveable valve that pops up and down does that sound correct?
Old Dec 28, 2011 | 10:11 PM
barneyb's Avatar
I'd have to crawl under before I could answer your question. That will have to wait until tomorrow.
Old Dec 29, 2011 | 02:57 PM
Dherch17's Avatar
Ok I'd appreciate it.
Old Dec 29, 2011 | 05:48 PM
barneyb's Avatar
Yeah, a little clicky button thing. The area around the one on my car is bone dry.
Old Dec 29, 2011 | 08:58 PM
Dherch17's Avatar
Yeah so is mine so I have no idea where the link is from..
MurderInc
Evo X How Tos / Installations
20
Dec 16, 2022 12:05 PM
chaotichoax
32
Feb 11, 2020 09:00 PM
SleepySamurai13
Apr 28, 2017 05:04 AM
664g63T
Feb 7, 2017 05:45 AM
Evoivnz
Oct 7, 2015 12:44 PM
