Building my first engine for a local customer
Old Feb 27, 2012 | 07:04 PM
  #106
tscompusa's Avatar
I'll slide a old bearing on it and see if it scratches the bearing.. if not i guess thats my answer. its just a tiny scratch.. it barely can be felt by your fingernail when you run right over it.
overall im very satisfied with your machine work.. so dont think im not. we checked the bore on the cylinders up and down and it was pretty good.. no eggshaping etc, the work was done right.
Old Feb 28, 2012 | 06:02 AM
  #107
TonyJAM's Avatar
If scratched at all it needs to be lightly polished.
Old Feb 28, 2012 | 11:49 AM
  #108
tscompusa's Avatar
yes its scratched. ill notify Stephen then.
Old Feb 28, 2012 | 03:19 PM
  #109
5LEEPERISAH23I's Avatar
i did not scratch the crank i can promise you that positive. Tom took it out of the bag you gave me and he noticed it right away. As i recall i never examined the crank kind of just took it and left. i am a NOOB at what to look for clearly.
took it to a local machine shop, talked to them on the phone he told me to bring it by so he could look at it. Both the people there said it was fine, but he said i could REDUE it but DONT have too. he said if the scratches were from left to right it would be alot worse then what it is.
BUT REGUARDLESS GETTING IT SCRATCHED UP AND BLAMING ME! haha thats a bunch of B*llsh*t -1 to JAM in my books.
Didnt give me a heads up on the block trimming, you can aruge that wasnt ur problem FINE but telling me never hurts to someone doing it the first time
hopefully it at-least runs all let everyone know how that goes!
Old Feb 28, 2012 | 07:18 PM
  #110
tscompusa's Avatar
should be good to go once we reassemble.
Old Feb 28, 2012 | 09:34 PM
  #111
R/TErnie's Avatar
Tom what is your assembled turning torque?
What was your side clearance on the con rods to the crank?
Old Feb 28, 2012 | 10:24 PM
  #112
tscompusa's Avatar
Hey Ernie,
I didnt measure the crank torque, but i will do it tomorrow and let you know.
I will say it was pretty easy to turn the engine after everything was assembled, minus the fact it hit the block half way
I didnt check the side clearance of the rods yet. ill let you know though what it is when i measure it. should be within the factory spec of .004 - .009
the rods dont have to much side to side play compared to my buschur engine. its built pretty tight.
Old Mar 5, 2012 | 08:08 PM
  #113
yea lets hope. There is nothing we did to damage the block for 1. and we did everything 100% right. putting it back together again is building a second motor
Old Mar 9, 2012 | 05:48 PM
  #114
tscompusa's Avatar
Some more pictures of progress. we have assembled the head and the short block is back together again also now after notching was performed.
Old Mar 12, 2012 | 09:00 AM
  #115
TonyJAM's Avatar
How do the bearings look?
Old Mar 13, 2012 | 11:37 AM
  #116
tscompusa's Avatar
Bearings look good. Scratches were nothing.. thanks Tony. We should have the car all together as soon as Steven gets back from his vacation.
Old Mar 15, 2012 | 09:45 PM
  #117
devildog08's Avatar
pimp!
Old Mar 26, 2012 | 12:25 PM
  #118
TonyJAM's Avatar
So my shop gets trash mouthed and come to find out there was nothing wrong to begin with? Unreal.
Old Mar 26, 2012 | 01:00 PM
  #119
R/TErnie's Avatar
Handling the situation professionaly is half the battle Tony.
Obviously you've been doing this far longer than Tom has and that's not lost on anybody.
Old Mar 26, 2012 | 01:46 PM
  #120
MRfabolous's Avatar
JAM is good in my book tony is always helpful and knows his stuff when in comes to motors. thanks god jam is under new management.
