Need help with bearing clearances and ring gap clearances?
Old Mar 13, 2012 | 12:48 PM
2006GSR's Avatar
Hey guys.
Setup is a 2.4L long rod 4g64. Manley I beam rods, wiseco 1400hd 87mm pistons 10.1 cr.
Any recommended bearing and ring clearances for over 500whp?
Thanks
Old Mar 13, 2012 | 12:58 PM
2006GSR's Avatar
So far I am getting .005" x bore to get my top ring gap. .0055"x bore for middle ring and .0015" for oil rings?
Old Mar 13, 2012 | 01:02 PM
okevolutionVIII's Avatar
That looks good but the oil rings don't need any work, just put them on the pistons. Bearing are good around .002-.0025.
Old Mar 13, 2012 | 01:48 PM
2006GSR's Avatar
Called my local Mitsubishi deAler and the oem specs are Rods: .004-.009" and mains are .0008-.0015". Today I am receiving my ACL race bearings so I will measure them to see what clearances they give me to begin with.
Also what head gasket to buy? I would prefer oem but do they make a oem 87mm head gasket?
Old Mar 13, 2012 | 04:49 PM
RSMike's Avatar
standard mitsubishi bearing clearances are very tight because it's designed for 300hp and 5W30 oil.
0.002" for both mains and big ends is about right.
Old Mar 13, 2012 | 05:47 PM
kailoma679's Avatar
I think my bearing clearances are: Mains @ .003, Rods @ .003, top ring @ .018, bottom ring @.022, piston to wall clearance .0035
Old Mar 13, 2012 | 06:26 PM
n2oiroc's Avatar
that seems really loose on the bearings and really tight on the pistons.
Old Jun 14, 2019 | 08:10 AM
Tyler Ransom's Avatar
Factory Service Manual pic
heres a screenshot out of the factory shop manual for 4g63 evo 8
Old Jun 14, 2019 | 01:33 PM
Pal215's Avatar
I would be ok with running those piston ring gaps and PTW clearances, but use tighter rod and main bearing clearances. Something like 0.0023" - 0.0025"
Old Jun 14, 2019 | 04:35 PM
LetsGetThisDone's Avatar
That was 7yrs ago. That motor either lasted, or it (probably) didn't...lmao
Old Jun 17, 2019 | 11:07 AM
Pal215's Avatar
Gotta love these old threads.
babaz7
34
Oct 13, 2017 04:57 PM
2006GSR
Mar 11, 2016 08:54 AM
MRfabolous
20
Sep 13, 2012 08:33 PM
craigybaby37
13
Sep 1, 2011 03:02 AM
LCS
11
Mar 14, 2010 05:47 PM
