variable vane mitsubishi turbo? TD05 based
Old Apr 11, 2012 | 02:20 PM
94AWDcoupe's Avatar
impulse buy of ebay.
cool turbo.
turbine is standard TD05H. center section standard TD05H. compressor wheel is small. but dont car much about that. turbo assembly weighs ~30lbs. here are some photos for your viewing pleasure. loving the high flow turbine wheel. gonna mate the bad boy with either a 68HTA or MAP EF1 compressor side. would estimate housing to be 20cm open and 2cm closed.
Old Apr 11, 2012 | 02:31 PM
Dallas J's Avatar
Veteran: Army
Is it just the turbine housing that you're changing then or the center also?
Cool project, Expect to see progress!
Old Apr 11, 2012 | 03:44 PM
ScorpionT's Avatar
The difficulty you will have with this project is controlling the inlet vanes. You will definitely be spending some time to come up with a working solution, but it would be cool to see it happen.
Old Apr 11, 2012 | 03:46 PM
4g63evoeight's Avatar
hmm, maybe its a turbocharger off a mitsu fusco diesel truck?
Old Apr 11, 2012 | 08:06 PM
03whitegsr's Avatar
Hrm
http://www.youtube.com/watch?v=8eJxY-AklI8
Wonder if there is any Mitsu with a reverse rotation version of that wheel and/or housing.
Old Apr 11, 2012 | 11:50 PM
94AWDcoupe's Avatar
I wish I knew what the turbo I have came off of...
the Pajero and Triton 2.5 VGT is not the same as this guy. that turbo is REALLY compact. maybe Garrett turbo?
here is a pic how small it is. it produces 350nm from 1800-3500 rpm on the 2.5. looks exhaust housing is half the size the one I have is.
Old Apr 12, 2012 | 09:05 AM
03whitegsr's Avatar
Is it a T3 flange pattern on that turbo you have?
Looks like it's almost an "on-center" housing though which usually hurt power and spool considerably. The vanes could make up for a lot of that though?
You taken the housing apart any further?
Old Apr 12, 2012 | 10:34 AM
Graphic's Avatar
Don't know if this will help:
https://www.evolutionm.net/forums/ev...er-turbos.html
94AWDcoupe
Jul 14, 2023 08:38 AM
94AWDcoupe
Sep 9, 2011 10:41 AM
94AWDcoupe
Sep 26, 2010 10:45 AM
94AWDcoupe
22
Aug 4, 2010 04:00 PM
94AWDcoupe
Aug 17, 2009 06:56 PM
