muffler delete = loud turbo?
Old Aug 7, 2012 | 05:38 PM
deraz's Avatar
I suspected an issue with my muffler (thinking the valve is stuck), so I removed the muffler to see if I regained some power. (yes I know, muffler delete is dangerous) I seemed to have gained a good amount of power which confirms my suspicions about the muffler but I have also discovered with the muffler gone the turbo is as loud as a shop vac on high at about 4500. Any one else seen this?
Old Aug 7, 2012 | 05:40 PM
ak47po's Avatar
No muffer will do that.What valve you talking about?
Old Aug 7, 2012 | 06:01 PM
deraz's Avatar
the flapper inside the muffler. I noticed a couple dents in the muffler right in that area and one exhaust tip is always dirty and the other one is always clean.
Old Aug 7, 2012 | 11:14 PM
06RedRalli's Avatar
Might want to have this moved to the 10 forums, this is under the 1-9. Lol we with 8-9 only have one muffler. But yes if the muffler is dented it is a possibility the valve is not opening.
Old Aug 9, 2012 | 05:46 AM
Raped's Avatar
To answer your initial question: Yes, with the muffler removed the turbo will be significantly louder. This is common. You will probably here the turbo whining at idle as well with the muffler removed (you will hear the turbine whining through the exhaust).
Old Aug 9, 2012 | 07:20 PM
GTijoejoe's Avatar
Originally Posted by deraz
...with the muffler gone the turbo is as loud as a shop vac on high at about 4500. Any one else seen this?
What did you think mufflers were for? awesome dude, made my day.
nor11384
Apr 15, 2017 12:54 PM
Igaly1021
Feb 13, 2014 10:59 AM
Sourav mahmud
Apr 16, 2013 08:46 AM
yitzac1990
Lancer Engine Tech
160
Jul 30, 2011 06:18 AM
Slowride
25
Feb 22, 2009 05:30 PM
