New times with BR clutchless 4 speed
Does this setup still use the Evo t-case and rear diff? If so, would those still be two items that a "serious" Evo drag car would want to upgrade?
The T-case and rear diff in the EVO are strong and proven reliable to run 8's. With the auto all the "shock" that is sent through those two parts to break them, is basically eliminated with this trans. The driveline is pre-loaded at the line and then stays loaded the entire run, this will make the rest of the driveline live even longer.
Yes, it uses the stock rear diff and an EVO T-case BUT the T-case has to be sent in to use to be machined to work.
Yes, I'd skip putting huge money into a t case or diff if you are going to run the clutchless trans. Obviously the ones you have can't be worn out junk and expect them to hold up.
I'm going to have to agree here. Wait until all the huge bugs get sorted out the upgrade when i KNOW there are ZERO issues, and cost to go down.
Looks to me that you'll be waiting for the rest of your life
