6 Speed Reverse Issue
Old Sep 14, 2012 | 06:44 PM
NewEnglandRT's Avatar
After I had my ACT clutch installed it became very difficult to get the shifter over to reverse. I really have to manhandle it all the way to the right before pulling it down into the gear.
I have some issue going from 1st to 2nd too.
I'm wondering what the cause could be? If it's something easily adjusted? Any other help.
T.I.A!
Old Sep 14, 2012 | 06:50 PM
nytalonTSi's Avatar
You can adjust the clutch pedal: https://www.evolutionm.net/forums/ev...djustment.html
I had this issue with a ACT 6 puck, streetlite flywheel and 6 speed.
Try putting it in say 3rd gear first, then put it in reverse.
I see you have the HDSS? When I had that clutch shifting was smooth for the most part.
Old Sep 14, 2012 | 08:27 PM
Yeah, I have a feeling it was misaligned when they installed it. I've done the other gear trick. Sometimes at start up I'll row the gears and it's a little better.
I'll review the clutch pedal thread, maybe it'll help a bit.
CaptainSquirts
May 17, 2016 08:35 PM
GSX 911
Apr 7, 2014 05:54 PM
clubEVO93
Jan 16, 2013 06:37 PM
Orodi
Aug 29, 2011 12:28 PM
SuperchargedGTZ
Aug 31, 2010 08:52 PM
