Question for someone running a FP HTA 71 on EVO 8
Old Dec 18, 2012 | 10:45 PM
rexwagon1909's Avatar
I am more then likely going with a FP HTA 71 for my 2005 MR, my question is for those who have then same setup on an evo 8 do you use the FP install kit that uses oil feed from oil filter, or the stock evo 9 install kit that uses stock oil feed etc. The reason I ask is #1 Price ($350 compared to $150) and #2 I had a friend with 1g that ran a Fp green with oil filter oil feed and it ended up blowing the seals on turbo.
Old Dec 19, 2012 | 04:36 AM
xxthayxx's Avatar
Stock evo 9 install kit should be fine. When i upgraded to the 71 hta, the only thing i remember having to get was the evo 9 j-pipe and wastegate actuator. Might have to bend the factory 8 lines a little.
Old Dec 19, 2012 | 07:42 AM
Awesome. What injectors are you running??
Old Dec 19, 2012 | 09:44 AM
sparky's Avatar
If E85 you will need bigger injectors than if you will only be running pump gas.
Old Dec 19, 2012 | 11:21 AM
xxthayxx's Avatar
FIC 1050cc injectors(E85/91oct) with a built 2.4LR motor.
Old Dec 19, 2012 | 11:27 AM
Fp is out of 71 hta until 2 week of Jan. What's are thoughts about green? I have read the comparisons it really comes down to daily driving
Old Dec 19, 2012 | 12:31 PM
korizmo's Avatar
Got the 71hta here with 84mm comp housing. I decided to buy the oil feed line from FP to make sure my turbo stays happy. I used my oem evo 8 turbo coolant lines, but had to bend them a little. Evo 9 J pipe was all that was needed.
Your looking at around 400hp with all the other bolts ons/cams with the 71hta/93/28psi and around 450 on e85
Running 880cc injectors
Old Feb 15, 2014 | 07:58 AM
Eray519's Avatar
Only difference I have with the last persons set up is I'm running GSC S2 cams and FIC 1100 injectors and I'm making 460whp and 445 tq. Love the turbo!
Old Feb 15, 2014 | 07:59 AM
Eray519's Avatar
Oh and that's also on E85!
nzevo8
25
Nov 5, 2020 10:02 PM
BrownSuga
Sep 28, 2016 03:56 PM
Biggy VIII
Aug 9, 2016 03:06 PM
KJS
May 10, 2016 07:40 AM
I4UnderPressure
49
Aug 11, 2012 04:41 AM
