evo 9 turbo untuned?
Old Dec 28, 2012 | 01:06 AM
triple L's Avatar
had mine on for almost a year driving untuned... the only difference i felt was it responded better and a little more power up top but i would recommend getting a tune for the full potential... didn't have any issues whatsoever on mine and boost was around 20psi compared to my 8 turbo at 17-18ish
Old Dec 28, 2012 | 01:53 AM
WikdEvo's Avatar
what's so hard about getting a tune?
Old Dec 28, 2012 | 03:44 AM
vaflyboi757's Avatar
Just don't kick the crap out of it until u getta tune and u'll be fine. Going WOT might not of hurt some people's motors but I wouldnt risk it.
Old Dec 28, 2012 | 05:57 AM
korizmo's Avatar
I went from a evo 8 turbo to a 71hta with all the bells and whistles.
I drove it around for 2 months until I could get a tune. Never took it past partial throttle or above 3500rpms. All was well.
Old Dec 28, 2012 | 09:31 AM
10isace's Avatar
As long as you don't WOT or anything close to aggressive driving it should be fine. If you WOT, you will/should hit loads at different RPM's that you're not tuned for. Also, you should get more air/boost in your engine causing you to go lean. Lean is bad. I suspect the timing will be low, but it's a guess without logging.
I guess the real questions are:
Why put the turbo on now?
Why not use your 8 turbo until you're about to get tuned?
Why drive around like a N/A car?
You do realize that you will not have any fun at all driving without boosting?! I tried to not boost for a full tank of gas (2 days) to see if I could improve my mpg. After a 1/2 tank I was like, "FO(K THAT!!!"
Old Dec 28, 2012 | 10:00 PM
WTXevolution's Avatar
i never said i wasnt about to get the evo tuned and i never said i drive it like an N/A car.. lol
i drive this **** like i stole it, its been icy out here latly and i slide the damn thing lol.
Im actually going to throw the turbo on tomarrow and next sunday im going to get it street tuned by a buddy of mine.
then here in a couple of months drive down the Evolution Dynamics in dallas and get a nice dyno tune =) hopfully ill have some GSC S2 by then too lol
Old Dec 28, 2012 | 10:01 PM
and what about spark plugs?
are BPR7ES colder then BPR8ES or is it the other way around? and which ones should i be running on a full bolt on evo 8?
Old Dec 28, 2012 | 10:19 PM
WikdEvo's Avatar
Infornextwreckedandblownenginethread
NGK Spark Plugs Heat Rating
The spark plug heat range has no relationship to the electrical energy transferred through the spark plug. The heat range of a spark plug is the range in which the plug works well thermally. The heat rating of each NGK spark plug is indicated by a number; lower numbers indicate a hotter type, higher numbers indicate a colder type.
Old Jan 4, 2013 | 02:56 PM
thanks i was just wondering which one was colder. and my car isnt going to blow, im a bit smarter than that.. but thanks for the comment ^^^
Polov93
Jul 22, 2016 06:17 PM
pinoy6969
Pacific Northwest
Jul 27, 2012 12:53 PM
ReignMan24
Jun 27, 2012 11:57 PM
JDM EVO PANAMA
Oct 24, 2010 06:05 PM
yellowevo82
Aug 12, 2009 05:30 PM
