Evo 8 with MAP EF2.5
Old Apr 3, 2013 | 04:47 AM
  #136
mean4g63's Avatar
Originally Posted by sparky
I am wondering about the differences in turbine wheel major and minor diameters on the EF2, EF2.5, and EF3 turbos. Maybe someone can clear up the wheel differences for me. For example, does the 2.5 combine the comp wheel from the EF3 with the turbine wheel of the EF2?
Yes. The Ef2.5 comes with the ef3 compressor and ef2 turbine. Map does not release their specs but I believe the ef2 is nothing more than the 65MM TD06 turbine wheel much like the Green, and the EF3 runs the TD06H 67MM turbine much like the Red. However with that being said it would be nice for someone to substantiate that.
the EF3 and the EF2 share neither turbine nor compressor wheels?
Correct both are different.
the lowest pressure spring available in the MAP/turbosmart IX WGA , a 16#, or an 18# spring, or is it sometimes refered to as a 16-18# spring. Thus there is actually only one spring but some refer to it as 16#, whereas others refer to it as a 18# spring? Just trying to get things straight, thanks.
The Map actuators comes with a 18 psi spring installed. It comes with a helper spring which will increase it to 23 psi.
Old Apr 23, 2013 | 06:30 PM
  #137
evotuner04's Avatar
15 Year MemberLikedLoved
updated first post with graphs. still a work in progress, going to switch out wastegate spring with bigger 23psi spring/adjust preload and maybe do a hybrid boost control setup. that wont be a for a few weeks though. thanks for looking guys!!
Old May 18, 2013 | 12:52 PM
  #138
evotuner04's Avatar
Found some issues with flapper not sealing right, this maybe cause of poor spool. We will see very soon. Turbo should be done mid next week and back in that night. Probably some retuning as well since my car was running a bit lean at higher rpms
Old May 18, 2013 | 05:07 PM
  #139
sparky's Avatar
What was causing the flapper to not seal properly?
Old May 18, 2013 | 07:49 PM
  #140
evotuner04's Avatar
machining was off just a little, flapper rested on the bridge instead of sealing on the outside of the port
Old May 19, 2013 | 10:18 AM
  #141
sparky's Avatar
OK. Thanks for the explanation. I can visualize it now.
Old May 19, 2013 | 10:41 AM
  #142
evotuner04's Avatar
No prob i'll have new results in asap. Hoping to have 25+psi by 4k
Old May 19, 2013 | 10:56 AM
  #143
DisgustipatedM3's Avatar
Cross posted from my thread... with light preload, I have achieved 25 psi by 4K RPM.
Attachment 334104
https://www.evolutionm.net/forums/10813510-post198.html
Old May 20, 2013 | 03:43 AM
  #144
sparky's Avatar
Originally Posted by mean4g63
Yes. The Ef2.5 comes with the ef3 compressor and ef2 turbine. Map does not release their specs but I believe the ef2 is nothing more than the 65MM TD06 turbine wheel much like the Green, and the EF3 runs the TD06H 67MM turbine much like the Red....
So, mean4g63, if I am reading this right, the EF2.5, is configured( at least wheelwise) roughly somewhere between the 73HTA Green, and the FP Red? This would be a neat turbo to ship over to Britain so as to have Owen Developments do a BB conversion on, huh?
Old May 21, 2013 | 08:37 AM
  #145
mean4g63's Avatar
Yup you got it. I know map has been considering a BB option as well in the future for their turbo's. Not sure how far they are with it at this point, but a ball bearing version would be nice to see on E85 @ 40 PSI.
Old May 23, 2013 | 09:03 PM
  #146
evotuner04's Avatar
Turbos back in car now feels good but needs a boost leak test bad, I feel like my TB is leaking.
Old May 24, 2013 | 03:43 AM
  #147
Ramonski's Avatar
I thought you were selling your 2.5? Did you decide to keep it?
Old May 24, 2013 | 10:47 AM
  #148
evotuner04's Avatar
For now, were too close to a local track weekend coming up in June to switch setups. Its the biggest event in MN for imports and MAP puts on the show which is badass. Might rebuild 2.0 after event better rods, pistons, etc I don't want a hole in this block
Old May 24, 2013 | 10:54 AM
  #149
Ramonski's Avatar
gotcha, sounds like a lot of fun. Good luck.
Old May 25, 2013 | 10:41 AM
  #150
evotuner04's Avatar
Thank you sir
