MAP EF2.5 Evo 8 E85 Results & Data
Old May 19, 2013 | 04:55 AM
  #196
sparky's Avatar
Originally Posted by mean4g63
definately. The EF3 compressor sucks at 22 psi (much like the red at this low boost). I am willing to put money on the fact my stock turbo is making more power than his 2.5 right now at 22 pounds. Definitely needs close to 30 pounds to make it worth while.
Good observation.
Old May 19, 2013 | 05:28 AM
  #197
sparky's Avatar
Originally Posted by DisgustipatedM3
Got my new WGA on two days ago... dialing in the power now.
....Using 22 psi spring with 4-5 half turns of preload..., according to the MAP sensor, it's making full boost at 3800-3900 RPM......
It is still spooling significantly slower than one would expect a 2.5 to be. My JB Red, which should spool about like a standard EF3, hits 20# by 3700-3800 RPM. The whole point of the 2.5 is that it should spool markedly quicker than a standard EF3.
Your 4-5 half turns translates to merely 2 complete 360* rotations. You have to try preloading it more to see if you can get it to wake up earlier.
Old May 19, 2013 | 10:38 AM
  #198
DisgustipatedM3's Avatar
Here's another boost graph... still working out some issues. The boost curve is fantastic though... hits 25 psi at 4000~ RPM, 28-29 by 4400, and holds 27+ PSI out to redline.
Would you suggest 7-9 half-turns of preload then? Where do I hit the limit of diminishing turns with preload on the arm? I can go preload it more right now.
I am going to say this: do not bother with the 18 psi spring in the WGA for this turbo. Go straight to 22 psi. I have no clue why MAP thinks it's OK to include the 18 psi spring in the WGA. This turbo REQUIRES the 22 psi spring.
Old May 19, 2013 | 10:46 AM
  #199
evotuner04's Avatar
15 Year MemberLikedLoved
Evotuner's for whatever reason. Honestly starting to like this little hybrid more and more. Produces good torque, decent spool numbers, and decent pump gas efficiency above 25 psi.
check my thread last page: https://www.evolutionm.net/forums/ev...f2-5-a-10.html
Old May 19, 2013 | 08:18 PM
  #200
mean4g63's Avatar
Spools pretty well. You have any tentative numbers for 27-29 psi?
Old May 19, 2013 | 08:25 PM
  #201
mean4g63's Avatar
Honestly it spooled right where I thought it would. It does spool a few hundred RPM quicker than an EF3 on average... Remember this is a non-mivec Evo 8 you are looking at. The turbine does appear to make significantly better torque numbers according to evotuner's dyno. So the spool numbers don't quite seem to show it all. The only question for me now is... at what power level (airflow) does that EF2 turbine become a bottleneck and the EF3 turbine becomes more beneficial in the trade off?
Old May 20, 2013 | 11:43 AM
  #202
evotuner04's Avatar
Where are his torque numbers in comparison to mine?
Also when I made 456 on the dyno that translates to over 500 on a dynojet which seems to be the norm for dyno results nowadays. I cant say that it really ever becomes a "bottleneck" what more do you want from a middle of the road (sized) stock frame turbo? My graph never fell flat on its face in the higher rpms, the turbo kept pulling. If you want 600 get an EF3 or EF4
We'll see here in about a week once mines rebuilt with a new turbine side if we can gain a couple hundred rpms and say 20ft lbs of tq
Old May 20, 2013 | 03:21 PM
  #203
EnjoyDriving's Avatar
Hi, Buddy No, i'm fine with my Ef2 now. Looking forward to see some new results from your rebuilt soon...
Originally Posted by evotuner04
Kai you thinking of getting a EF2.5?
Old May 20, 2013 | 10:41 PM
  #204
mean4g63's Avatar
Are u referring to my last post? if so, I did mention "according to evotuner's dyno". If my info is correct the Ef2/2.5 turbine is a 65MM TD06. If that's the case it has displayed good torque numbers on yours, and a multitude of FP Green's out there (even though FP uses a slightly different aero). So it's reasonable to assume it will produce better torque numbers compared to an EF3 on average as yours has shown.
Well considering you are only around the 50 lb/min range of compressor that flows 60 lb/min, you really aren't pushing that compressor or turbine. Remember a hybrid is only a good match if the turbine wheel will support the compressor flow. So it remains to be seen if that compressor is a good match for that turbine on the higher pressure ratio and flow numbers. The larger 67MM turbine will flow more. Period. So there will be a point of diminishing returns where the EF3 will be much more beneficial in overall performance. Where that exact point is, is hard to say. Only time will tell, but it's reasonable to assume that this little hybrid is good for a small window of power, pressure ratio, and needs a more focused setup for it to be beneficial. Remember this isn't the first time a turbo manufacturer has built a hybrid out of existing turbos. For instance the GT3076, GT3082, and BW262. All of these hybrids were failures at least a certain extent. For reasons of mismatching compressors with a turbine that won't support it. So like I said, time will tell.
well good luck to you. Look forward to the results.
Old May 29, 2013 | 09:34 AM
  #205
j255c's Avatar
sticking with my stock IX turbo, dont see the point. If i want >500whp ill consider an ef3 or red. Other than that not worth the hastle in my opinion.
BBK Full(Non BB) still seems like the best mid 400's turbo while retaining similar to stock spool.
Old May 29, 2013 | 05:32 PM
  #206
evotuner04's Avatar
any news on this sir?
Old May 30, 2013 | 06:47 PM
  #207
Ramonski's Avatar
I got mine tuned but my fuel pump needs to be replaced so I wasnt able to finish the tune. We ended at 393hp @ 24psi on 93. No e85 tune for now. My tuner said it has some more in it but he cant up the boost until I replace my fuel pump. I'm still on the stock cams so I know thats holding me back quite a bit. Im very happy with how the car sits now though. It pulls smooth all the way through redline. I love that it does not run out of breath up top like the stock turbo did.
Old May 30, 2013 | 08:02 PM
  #208
Hi Im Vinh's Avatar
Was this on a dyno ?
Old May 30, 2013 | 08:06 PM
  #209
evotuner04's Avatar
graph?
Old May 30, 2013 | 08:14 PM
  #210
Ramonski's Avatar
Yes it was on a dyno. I think it was a dynojet but cant be 100% as it was the first time I have been to that shop. Unfortunately, I dont have any graphs because his printer was not working. I have done a few pulls on the street using virtual dyno to compare and it was very close to the "real" dyno #.Those are the only graphs I have but they are on my laptop so I cannot post them up at the moment. Overall, im very pleased with the turbo and its a great daily driver upgrade for sure!
