How to build a 4G64 for an EVO 8/9
This is a great writeup, thanks for the hard work. I have not done any research whatsoever on these builds, could you use the evo 9 head instead? Or no because of mivec. Im pretty interested in building something like this later on for a backup motor or better
It probably wouldnt hurt to add the oil squirters. I just picked up my block yesterday. Im going to take it to the machine shop and see how much it would be to add them. As far as advantages go, it keeps the pistons cooler. I have seen high HP builds without the squirters. In my opinion, if the EVOs were built with them, they should be installed.
You can use the evo 9 head with Mivec. You have to relocate the oil line for the mivec to work. There is a link with the line you will need in the original post.
