Cam decision help
Old Apr 9, 2013 | 02:07 AM
the_evodude's Avatar
Cam decision help
Hey guys
I have a 03 Evo 8 with bolt ons
catless tbe, licp, intake, evo 9 bov, walbro 255, gm 3 port and a tune
Im planning to install evo 9 turbo, bigger injectors and cams
im looking at the hks 280 and gsc s1 as they don't require upgraded valve spring/retainers/seat.
I've read that they are both great for stock turbo
I was wondering which would be the best set of cams for my setup, just looking to get the most out of the evo 9 turbo as i most likely won't upgrade the turbo.
thanks for the input
Old Apr 9, 2013 | 02:16 AM
ctfpevoVIII's Avatar
Originally Posted by the_evodude
Hey guys
I think I have read that some guys run the 272 kelfords with stock springs and retainers, but I think they would probably be better with changing them though. I say gsc s1's.
Old Apr 9, 2013 | 02:35 AM
fugiwara's Avatar
The MOST popular cams for evo8 are Kelford 272 and GSC S2, do the springs!
Old Apr 9, 2013 | 03:14 AM
MR. EVO MR's Avatar
When I had my 8 I first did Comp cams 272 with new springs and retainers, when I went bigger turbo I replaced them with Kelford 272 and didn't look back. The high rpm pull is amazing!
Old Apr 9, 2013 | 01:55 PM
anybody have experiences with the hks 280 on an evo 8
Old Apr 9, 2013 | 05:08 PM
foxbat's Avatar
Do you have a 9.8 or 10.5 hotside turbo? I don't think that the difference between 8-9 turbos is significant enough, either upgrade to larger than stock or stick with the 8's.
GSC S1 & Kelford 272 are both good choices, I won't go past 272 sized cams with a stock turbo.
Old Apr 9, 2013 | 05:10 PM
EvoJoeIX's Avatar
I loved my s1's on stock turbo. Increased power over the entire powerband
Old Apr 10, 2013 | 11:12 AM
joeBPUsupra's Avatar
I went tomei 270 procams on my evo 8. If I had to do it again......I would. With Just the change in cams, I went from 314whp to 349whp UNTUNED!!! Once tuned, it did 363whp/ 364tq @25psi 93oct on a Mustang dyno. Obviously with the amount of lift, I had to also get valve Springs and retainers. I still had the stock short block and stock injectors.
Old Apr 10, 2013 | 06:36 PM
sofastsoreal's Avatar
i ran kelford 280 w/spring retainers and love them. made 342whp 91 oct and 432whp e85 on my evo ix
UmbraEVOlveD
Jan 22, 2014 02:39 PM
EVO'D8
16
Mar 25, 2013 11:52 AM
steven121
Aug 23, 2012 07:58 AM
Rmeister007
Jul 23, 2012 12:37 AM
skatermsmn
14
Feb 23, 2009 04:19 PM
