HELP! went from 4th to 3rd
Old May 8, 2013 | 02:39 PM
TougeGod7's Avatar
Unhappy HELP! went from 4th to 3rd
so last night i did a pull and as i went to shift into 5th on of the under hood shifter bushings fell out casing me to go back into 3rd
the car seemed to run fine after, but is there any way to check the valves to see if any are bent/damaged without removing the head? also, what should i check to make sure everything is still running correctly? i'm a bit of a n00b when it comes to real mechanical work
Old May 8, 2013 | 02:42 PM
llDemonll's Avatar
leakdown test will usually tell you if you bent valves
you should be looking into why the bushings fell off though..they are held in with pins to secure them, there should be no way for them to fall off
Old May 8, 2013 | 02:56 PM
TougeGod7's Avatar
will do and as far as the bushing falling out, i believe the retainer clip failed that was holding the two bushing together (AMS' design has 2 pieces that sandwich together)
Old May 8, 2013 | 03:00 PM
meckert's Avatar
If you bent a valve your car would essentially run like its on 3 cylinders or less, and be way down on power.. You mentioned none of these issues, your fine.
Old May 8, 2013 | 07:38 PM
Faisalm's Avatar
Ouch... That must have been painful to experience I bet... Hope no damage has been done!
Old May 8, 2013 | 07:47 PM
4RETECH's Avatar
Yeah, do a cylinder leak down test and you will know if anything happened.
Old May 8, 2013 | 11:27 PM
chinoxmk22's Avatar
damn, that sounds painful .
Old May 9, 2013 | 05:57 AM
heel2toe's Avatar
How high of an RPM did the engine get to before you pushed in the clutch?
Old May 9, 2013 | 06:46 AM
Raptord's Avatar
3 valves in my engine were slightly bent but not enough for me to have any symptoms you described. So not having those symptoms doesn't necessarily mean the valves aren't bent.
514_evox
10
Oct 25, 2016 07:48 PM
blknblubkrdude
Jan 18, 2016 01:08 AM
Llew
Oct 14, 2015 03:14 PM
millsyy17
17
Sep 5, 2011 12:22 PM
chase123
Feb 9, 2009 09:00 AM
