Weird noise....Drivetrain?
Old May 31, 2013 | 01:37 AM
bayaraa524's Avatar
hello.. ill change my evo8 transfer case of airtrek turbo awd.. and its same or?
Old May 31, 2013 | 03:54 AM
scothu's Avatar
transfer case is going out =/ happened to me
Old May 31, 2013 | 04:10 AM
way2qik's Avatar
Call John at TRE. He will fix it right and it won't take 2 months.
Old Jun 1, 2013 | 10:39 PM
AndyCT9W's Avatar
Originally Posted by Big Bald
So if I leave it in gear and let off the noise gets quieter which is what you heard in the video. If I put the car in neutral and then let off the sound is unchanged. Not sure if that means anything.
If the noise stays there when you're in neutral then it means it is not to do with your engine, clutch or trans (not 100% sure about the trans, maybe someone can confirm).
So now you're looking at anything that moves (most likely rotates) from the transfer case to the wheels. A lot of people will say the transfer case is the culprit, which is entirely possible but I personally would like to have some evidence to support it other than it being the weak link in the evo drivetrain.
The fact that it changes when you let off the throttle means that it is something that is affected by load from the engine. So probably not wheel bearings or tires.
Get it up on a lift and have a listen while the wheels are spinning. Once you know exactly where the noise is coming from you'll start making leaps and bounds towards a solution.
Old Jun 1, 2013 | 10:59 PM
iceman1189's Avatar
listening to what you have going on sounds like your transfer. I haven't had to deal with this problem thank god but some friends of mine have before and it was just like what your experiencing. There is a possiblity ur transfer isn't the problem but it's definately a very high chance it is.
Old Aug 3, 2019 | 10:11 AM
Quattlebot's Avatar
Op you ever figure out this problem?
Lancerfry30
Nov 14, 2016 11:25 PM
Lancerfry30
Feb 28, 2016 02:45 PM
ashton13
Apr 19, 2015 08:09 PM
honda-guy
12
Mar 25, 2013 06:25 AM
jyamona
Apr 11, 2012 06:02 AM
