Car heating/cooling issues: Educated opinions welcomed
Old Jul 15, 2013 | 06:52 AM
  #31
SmurfZilla's Avatar
No leaks.
I'll be looking into Chad's suggestion as well as trying another radiator (either CBRD's again or ToxicFab).
Old Jul 15, 2013 | 06:53 AM
  #32
SmurfZilla's Avatar
Originally Posted by 211ratsbud
Anti freeze is also anti boil last time I checked.
Your car just has a lot of calories
Did anyone mention water pump? Have you checked flow from that ?
HAven't checked water pump. Its got maybe 3000 miles on it so I never though to check it.
Old Jul 15, 2013 | 11:18 AM
  #33
211Ratsbud's Avatar
I do wonder if you used an oem water pump or aftermarket, and is it possible there's a slippage on the shaft either internally or on the pulley itself?
Old Jul 15, 2013 | 08:45 PM
  #34
rstchris's Avatar
It runs cooler stopped cause the fan runs under 25mph (on most cars) so I think you need to promote airflow across the radiator. Throw some small 1" air diverter plates on the sides of the setup and seal the condensor core to the raditor core and it "should" improve.
To check my theory, override the fan relay with a jumper and take it for a cruise, logs temps and see if the fan helps while on the highway.
Old Jul 16, 2013 | 06:48 AM
  #35
SmurfZilla's Avatar
I will try that this weekend. Thanks
killerpenguin21
Jun 23, 2015 12:22 PM
evotris
Jul 6, 2014 10:01 PM
88888
Jun 13, 2013 08:40 PM
meckert
Aug 25, 2011 06:20 PM
KevinD
11
Apr 21, 2008 12:45 PM
