4g64 head gasket recommendations
Old Sep 22, 2013 | 02:25 PM
howell's Avatar
I have a built 2.4 with a big valve cosworth head, it is pushing coolant when i hit full boost. So it currently has the cometic MLS gasket .51 thick with the cosworth studs. I don't know if the tune, studs, or gasket were the issue. Either way I am debating on what gasket to use, and whether I should go with either the l19 or 625 custom aged studs? I just don't want to have to deal with this again... At least for a while.
If u are running a 2.4, what gasket are you using, what power are you putting out, and how long has it lasted you so far?
Old Sep 22, 2013 | 03:01 PM
evolve_VIII's Avatar
Im running the l19 studs and stock evo 8 gasket. 45psi no problem. I had the gasket bored with the build and had an extra one made as well. 650whp only 1000 miles on it so far.
Old Sep 22, 2013 | 03:05 PM
howell's Avatar
What kind of dyno did u put down 650whp? And SD or MAF?
Old Sep 22, 2013 | 09:07 PM
Fast_Freddie's Avatar
Veteran: Navy
I am using +625 studs and a cosworth 87mm head gasket... 35psi no issues...
Old Sep 23, 2013 | 09:18 AM
Mustang. SD. E-85.
Old Sep 23, 2013 | 03:46 PM
howell's Avatar
Mustang. SD. E-85.
I was hoping that was on a mustang dyno with that much boost.
Old Sep 23, 2013 | 06:28 PM
silentkiller's Avatar
Get the Ams modified Oem Gasket... I use the cosworth 87mm on my 2.4LR...out with a leak aft tune tuning..
Old Sep 26, 2013 | 01:02 PM
howell's Avatar
So the cosworth went out, or it didn't go out. Haha, kinda confused on ur comment. AMS dosnt sell their gasket any more.
Old Sep 27, 2013 | 01:59 PM
^^ i mean the cosworth hg leak... U get awd to grab the ams for u..
Old Sep 27, 2013 | 02:14 PM
boostedwrx's Avatar
Look into getting the head o-ringed too.
Old Sep 28, 2013 | 09:02 PM
howell's Avatar
Buschur, AWD, SBR ect got there's from AMS and AMS will not sell them any more.
Old Jun 19, 2014 | 08:06 AM
NOMIEZVR4's Avatar
Not trying to bring a thread up from the dead but what gasket did you end up going with?
Old Jun 20, 2014 | 02:14 PM
Andrew b's Avatar
The Norris design option seems to be reliable with the H11 stud kit
Old Jun 20, 2014 | 04:08 PM
NOMIEZVR4's Avatar
Looks like they use a cosworth gasket.
nomnom
May 30, 2017 05:58 PM
OneSlowX
Feb 24, 2015 11:32 PM
maperformance
Evo 'For Sale' Engine Internals and Drivetrain
Jan 22, 2015 12:05 PM
BadassEvo8
Jul 31, 2014 01:20 AM
ezz-e
30
Sep 2, 2012 12:06 AM
