Oil recommended for a BB Fp Red
Old Nov 18, 2013 | 10:52 PM
Silver-IXse's Avatar
Hey there i need help on what oil i should run on my BB Fp Red ... What kind of oil do you guys run on this turbo Im thinking of running the VR1 10-30w but i wanna knw what you guys think please help me out .... Thanks
Old Nov 18, 2013 | 11:18 PM
xXANCHORMONXx's Avatar
if your on e85 run Amsoil 10w-40 High zinc
If your on pump rotella will be fine
Old Nov 18, 2013 | 11:54 PM
Im running 91/e-85
Old Nov 19, 2013 | 12:05 AM
itsmrrizz2you's Avatar
The preferred oils to use are on fp website... I use brad penn 20-50 year round
Old Nov 19, 2013 | 12:07 AM
wang4u's Avatar
Heres exactly what FP recommends for their turbos.. http://store.forcedperformance.net/m...otor%20Oil.pdf
Im personally running VR1 10w30. Not a problem yet. I believe the best is Amsoil Dominator. Has the highest ppm of Zinc (1575ppm) and Phosphorus (1424ppm). VR1 is in the low 1100ppm for both zinc and phosphorus as an example.
Old Nov 19, 2013 | 12:08 AM
Have you guys trued using the Vr1
Old Nov 19, 2013 | 12:21 AM
wang4u's Avatar
Lol. I said I am, on a FP Black.
Old Nov 19, 2013 | 03:04 PM
apagan01's Avatar
Old Nov 19, 2013 | 05:13 PM
Craig King's Avatar
The valvoline VR1, are you guys running the synthetic or standard version? I think one is $6/qt .... the other is $12?
Old Nov 20, 2013 | 03:34 PM
FlaEvolution's Avatar
Brad Penn is what I've been using and won't look back.
Old Nov 21, 2013 | 04:56 PM
Big Daddy Mango's Avatar
I'm using VR1 20-50 on a FP BB RED. This was recommended from JMS in San Antonio. I only use e85. Oil is changed after every track day (monthly).
I have noticed that after the new turbo upgrade and using the VR1 oil my oil temp is up about 10 degrees to 192 on daily drives. Could be the turbo. Prior to the upgrade it was always Mobil 1 5-30
Old Dec 9, 2013 | 06:01 PM
evo9gsrmike's Avatar
Which oil do you guys recomend if your car is mainly running on e85 ? I usually use amsoil dominator series or vr1 but just wondering if there's anything better to use with e85
febs1011
36
Feb 19, 2016 03:35 AM
XSivPSI
Dec 17, 2015 07:08 PM
febs1011
Sep 4, 2015 03:28 PM
Anees
35
Aug 24, 2013 12:04 PM
MDH-005
21
Jan 9, 2013 09:11 AM
