Intercooler piping diameter, how big of a difference between 2.5 and 3" diameter?
Old Jan 8, 2014 | 06:41 PM
boostawd16's Avatar
hey guys im in the process of building a 2.4LR with my goal to 1000hp. My issue is all the intercooler piping i can find is 2.5" and i really wanted 3" but cant find any. How much of a difference will there be if i go with 2.5" instead of 3? If you know where i can get 3" piping either that would be awesome. Let me know your opinions on the difference in diameter.
Old Jan 8, 2014 | 06:52 PM
meckert's Avatar
You really need to look at the whole system. Can you get IC piping at the intercooler to 3", can you get IC pipes to 3", can you get IC soft couplers in 3" is the TB 3", is the inlet to the manifold 3"?---my point being that somewhere in this mess your not going to get to 3" and it becomes the restriction in flow...so even if the rest is 3" your going to run into that restriction and negate your other improvements.. in the event you have resolved all these other restriction points, my guess would be ETS would listen to you and custom build a set-- just guessing.
Old Jan 8, 2014 | 07:00 PM
boostawd16's Avatar
I plan on doing a ams intake manifold and bigger throttle body with the setup so i should have 3" all the way around
Old Jan 8, 2014 | 07:29 PM
211Ratsbud's Avatar
There was a test somewhere around here. Did you search?
Old Jan 8, 2014 | 07:37 PM
211Ratsbud's Avatar
https://www.evolutionm.net/forums/sh...697&styleid=27
https://www.evolutionm.net/forums/sh...610&styleid=27
https://www.evolutionm.net/forums/sh...d.php?t=328389
Old Jan 8, 2014 | 08:10 PM
e_kobz's Avatar
Here is a 3in UICP from STM: http://www.streettunedmotorsports.co...ipe_3_inch.htm
The downside is this UICP can't be used with Evo's that have an ACD, and judging by your info I can see you have a 2005 Evo 8. So that's not gonna work. In regards to the hot side, I can't think of anyone who sells a 3in LICP. Looks like you might need some custom fab work for your setup.
Old Jan 8, 2014 | 08:15 PM
e_kobz's Avatar
I just found this, it's a 3in UICP from JM Fab. It doesn't say anyting about not being able to be used with a ACD equpied Evo. Just to be safe I would definitely call.
http://www.jmfabrications.com/store/...-Pipe-Kit.html
cstylez52
Dec 27, 2014 12:12 AM
rice_rocket88
Mar 22, 2014 06:55 PM
RallyartRob
Dec 8, 2012 06:50 AM
x2003lancerESx
Feb 2, 2012 04:25 PM
Evoisdream
15
Dec 28, 2005 08:26 PM
