MBC void warranty?
Old Mar 4, 2004 | 09:46 AM
ZeroFrost's Avatar
MBC void warranty?
Just out of curiousity. If i put a MBC on my EVO will it void the warranty? And if i do put 1 on, is there a way to take it off b4 i take it in to mitsu?
Old Mar 4, 2004 | 09:49 AM
AWDOWNZJ00's Avatar
Yes and Yes
Old Mar 4, 2004 | 10:01 AM
mifesto's Avatar
they probably cant void ur suspension or body but they'll void ur engine and tranny.. which is basically 90% of the problem anywayz
Old Mar 4, 2004 | 12:22 PM
evo542's Avatar
I don't think they would know unless they get really ****
Old Mar 4, 2004 | 01:06 PM
osunick's Avatar
it's pretty obvious if you have an MBC installed, especially since you have to mount the MBC in a convenient (and visible) place... also deinstalling is possible but a big pain.. I put a hole in my radiator removing mine because removing the fan is tricky. If I ever put a boost controller back in, I'll probably do it from below, which seems much easier to me than removing all that IC piping and the fan. You'll need a friend to help you lower the hoses from above... but it's very doable.
I took my MBC out because I didn't want to get busted on warranty if I ever had to bring my car in for service.. IMO an ECU upgrade makes more sense.
Old Mar 4, 2004 | 01:31 PM
EvolvedDSM's Avatar
I think I'm going to have to disagree with almost everything in this statement.
Old Mar 4, 2004 | 01:43 PM
Chris in HB's Avatar
Care to explain?
Old Mar 4, 2004 | 02:16 PM
Secret Chimp's Avatar
No aftermarket part installation will just simply void your warranty.
You can certainly be denied coverages if you go in for warranty repair and it is decided that the part caused the failure. But merely installing the part will not end your warranty coverage.
Old Mar 4, 2004 | 02:18 PM
jasonc32amg's Avatar
that could get messy...
Old Mar 4, 2004 | 02:24 PM
scottatyamaha's Avatar
You would never know I had a MBC on my car
Old Mar 4, 2004 | 02:36 PM
MalibuJack's Avatar
I had an MBC on my car for some time.. I mounted it on the fan bracket under the snorkle so it wasn't easily seen.. The dealer is aware of my modifications however and said if they found something that required warranty replacement and the part was to be inspected by mitsubishi, they would return the car to me to swap the parts back to stock if I wanted to before they had them come down. I do admit I have a better relationship than most with my dealer and their service center.
Old Mar 4, 2004 | 03:14 PM
EvolvedDSM's Avatar
Originally posted by Chris in HB
Care to explain?
Okie dokie:
An MBC is small and easy to hide. Route the vacuum lines along the stock pathway and it makes it even more convincing. Granted, if you want to adjust it often, you would want it accessible, but not necessarily visible.
If you put things back together in a user-friendly manner, removal and reinstalling the stock items are a snap--much easier than the first time.
This I well tend to agree with, but it is completely unnecessary to remove the fan.
I wouldn't even bother trying to fight the lower covers. The time wasting just getting them off and you could easily be done with the entire job. Involving a friend... two man MBC install? I wouldn't go near that shop Again, removal of fan and intercooler piping is unnecessary.
Good move
Bad move A $20 MBC is a much wiser investment. I'd spend the hundreds of dollars I'm saving on a Pocketlogger, AFC and/or other goodies.
Old Mar 4, 2004 | 03:33 PM
mifesto's Avatar
maybe i should just cover it up with tape hehehehe
Old Mar 4, 2004 | 03:57 PM
Thanks for the explanation - I wasn't flaming, just wondering what the justification for your brief statement was. I am getting my PE boost gauge/controller installed Monday, so this topic was relevant.
Old Mar 4, 2004 | 04:04 PM
mifesto's Avatar
if i put back the stock boost controller .. i'm definetly going to granny shift...
Mountainbiker54
May 16, 2008 11:40 PM
IgotaWhiteOne
Oct 22, 2007 06:11 PM
jvans04
Northeast Region
Jan 29, 2007 09:44 AM
binsento
Lancer Engine Tech
13
Apr 3, 2006 11:54 PM
PinnacleChronos
Jun 6, 2004 04:17 PM
