Slight gear grind. Help.
Old Jun 20, 2014 | 11:42 PM
IX_MR's Avatar
Car is an evo 9 MR with the 6 speed tranny. 30k miles.
the car runs good. Just has a couple
Bolt ons and no crazy power.
Recently I've noticed when I shift from 3rd to 4th gear while in boost and at higher rpms, there's a slight grind. The gear still goes in but there's a grinding sound.
I don't know the last time that the tranny fluid has been changed but I am planning to change that soon. do you think it's the synchro that's going out? Or maybe there's something that I have to adjust?
Thanks.
Old Jun 21, 2014 | 04:50 AM
evo8426's Avatar
Adjust the rod on the clutch pedal, 12mm locknut has to be loosened and then you can turn the rod a little bit by hand.
Old Jun 21, 2014 | 05:40 AM
slowsrt4:('s Avatar
try adjusting the clutch and change the fluid, when you change the fluid look for sparkles in the used fluid
Old Jun 21, 2014 | 09:16 PM
IzzyRS's Avatar
There is a how-to for both the fluids and clutch adjustment! Get those done and report back with the results.
Kreeker
Feb 5, 2016 01:52 PM
Patrrrick
Feb 2, 2014 08:54 AM
vietdragontekx
18
May 3, 2010 11:02 AM
SleepySamurai13
15
Apr 29, 2009 12:53 AM
gfd205
Lancer Tranny/Drivetrain Tech
10
Sep 11, 2004 03:15 PM
