God.......I hate mivec
Old Aug 27, 2014 | 12:00 PM
thepoint4life23's Avatar
Man That sucks. Ask Boostin what it takes to go to a evo 8 head since they did it to the junk box they you will have no more mivac.
Old Aug 27, 2014 | 01:51 PM
tsidrift1's Avatar
Well, I looked up the part I broke and luckily it's only about $25 as mentioned before, so that's a relief. I am gonna get a hold of Boostin abiutbtje evo 8 stuff, might be worth while for me.
Old Aug 27, 2014 | 05:29 PM
JohnBradley's Avatar
You can leave the IX cam sensor housing on to plug the aft end of the cam. I would plug the block oil feed and the inlet to the feed solenoid. On the ECU side you need to disable the sensor check in the OBDII section.
Old Aug 29, 2014 | 05:42 PM
mrfred's Avatar
interesting discussion.. i rather like mivec. i can run a big cam and idle like stock. besides that, i was under the impression from mitsu tech documents that the mivec head has a water passage design that better pulls heat from the head. also, i thought the mivec head has a better dome shape.
Old Aug 29, 2014 | 08:13 PM
tsidrift1's Avatar
Im sure there are plenty of advantages. Myself though, I have just had bad luck with mivec and its equipment lol.
I have broke the electrical terminal off of the mivec pressure valve twice and had to replace, then broke the filter off in the head the other night lol. I got the piece out of the head tonight though.
Sheasta
Feb 14, 2021 09:00 AM
Ramatzio
Oct 10, 2016 06:55 AM
Biggy VIII
Aug 9, 2016 03:06 PM
EVOkeeper
Jun 22, 2014 08:43 PM
Javier F.
Dec 28, 2011 11:43 AM
