Help! Strange Ringing at idle fresh 2.4LR
Old Nov 24, 2014 | 09:35 AM
memphis raynes's Avatar
I just had a new 2.4LR built and installed. Engine has about 700 miles on it. When I first got the car back from the shop, it has this very light ringing noise at idle - like a bell ringing. Thought maybe it was the PS pump or something like that.
It's gotten progressively louder as I have driven my car. The engine is a (4G64) 2.4L LR with Manley Billet Crank, JE Pistons, Manley Turbo Tuff iBeams, ACL Race Bearings, etc..
I thought maybe it was the water pump or something like that, so I removed the accessory belt to eliminate any rotation from the Alternator, Water Pump, PS Pump, or AC compressor.. Sound is still there at idle. I've determined it's not the clutch - sounds the same in or out. Something in the engine. Below is a video so you can hear it.. What do you guys think this sound is? What should I look at? I am not driving the car till I figure out that the heck this is.
Thanks in advance for your help!
Old Nov 25, 2014 | 10:49 PM
I found the issue... Crank sensor tooth wheel was rubbing on the Crank Position Sensor. Slightly bent it back flat and sound is gone.
Old Nov 26, 2014 | 06:12 AM
evolve_VIII's Avatar
you should probably replace it since it was hitting. You may find problems down the road.
masonh
Nov 30, 2014 08:40 AM
Corbin09
17
Oct 24, 2014 09:12 AM
pd9000
Jul 21, 2013 11:58 PM
PATRICK B.
Nov 10, 2007 02:03 PM
Biggins82786
Apr 14, 2006 06:44 AM
