New stock frame turbo options from Blouch
I would think SOMEONE will step up and deliver- there's obviously a HUGE market for these still- a lot of people are happy with their setups and might simply need to replace a turbo etc.
Me: Are they available with an anti-surge housing?
Mike at Blouch: Turbos can be built with the 3.5inch inlet with anti surge ports.
I am not saying the new XTR's will surge (as this depends ALOT on your individual setup but I know some people ended up swapping to the FP anti-surge covers on their BBK's) https://www.evolutionm.net/forums/ev...-27-psi-4.html
Just something to consider when choosing a turbo for your specific application.
It will be awhile before I get the turbo on and tuned but mods are the following.
Injector Dynamics 1000cc injectors
Walbro 255
ETS 3.5'' Intercooler
ETS UICP/LICP
ARC intake
MAP 02 Eliminator downpipe (recirculating)
3'' no name catback exhaust
Stock Head
2.0 Block being built with Manley Turbo Tuff I-Beam rods with Wiseco 1400HD pistons
I will eventually upgrade cams to GSC S2s with Kiggly beehive valve springs.
Walbro 255
ETS UICP/LICP
ARC intake
Stock Head
i had the bbk full and it was awesome spool up was insane, if any of these even come close that should be nice. mine is being built right now i went with the fp zero but yeh had to change everything except manifold hope its worth it
I will most definitely. But this build is moving at a snail's pace. Need to get the rings WPC treated and possibly the bearings, then shortblock will go out for assembly. Then comes the head, where I will be doing a slightly non-traditional valve-job based on Aby's recommendations and possibly be making some tweaks/improvements to the windage tray once we get around to putting the oil pan on.
