10.5 vs IX turbo- accuator different?
Old May 20, 2015 | 09:42 PM
alexc's Avatar
I picked up a IX cold side housing I am planning to swap onto my evo 8.5 turbo (10.5 hot side)
I know i need a new j pipe and oil lines to put the new cover on.
Do i need a new WGA as well?
Old May 20, 2015 | 10:49 PM
LetsGetThisDone's Avatar
You'll need the 9 actuator. And a 9 compressor wheel..
Old May 20, 2015 | 11:55 PM
alexc's Avatar
compressor wheel is the same for the 8.5 turbo...
Old May 20, 2015 | 11:59 PM
deylag's Avatar
The wastegate is the same.
Old May 21, 2015 | 03:40 AM
evo8426's Avatar
If you do end up needing one I have the OEM one from my car where I recently moved into a Red.
Old May 21, 2015 | 10:16 AM
I'm pretty sure the compressor wheel is different seeing as how the 9 turbo flows more...
Old May 21, 2015 | 10:31 AM
ronaldo9's Avatar
From this thread: https://www.evolutionm.net/forums/ev...8-5-turbo.html
Compressor wheels and turbine wheels are the same on the VIII and the IX turbos. The IX has an improved compressor cover(housing).
An 8.5 turbo is essentially your VIII turbo fitted with a 10.5cm turbine housing instead of the 9.8 turbine housing. That is the only difference. So, to convert your VIII turbo into an 8.5 turbo just pick up a 10.5cm turbine housing and swap turbine housings.
The IX turbo has the same compressor wheel and the same turbine wheel as your VIII turbo does. The IX turbo's compressor cover is an improved design compared to the VIII compressor cover.
Old May 21, 2015 | 03:04 PM
alexc's Avatar
yes, these things i know
I need to verify that the waste gate actuator is the same though
Old May 21, 2015 | 03:05 PM
alexc's Avatar
it may be differently shaped because of the larger compressor housing on the 9 turbo
Old May 21, 2015 | 05:42 PM
ronaldo9's Avatar
The difference is the length in the arm. that is all.
Old May 21, 2015 | 07:19 PM
alexc's Avatar
thank you!
now... does anyone know where i can get the arm...
DWAIST
Jun 13, 2007 04:58 PM
bishiboy
Sep 29, 2005 08:59 PM
BigLEVO
Mar 13, 2005 07:15 AM
