Self-Built oil pan
Old Feb 24, 2019 | 02:00 PM
  #301
kaj's Avatar
kaj
Originally Posted by 2006EvoIXer
The sheet metal they used is much thicker than oem pan. I'd guess it's at least twice as thick...and can hold up to rocks hitting it for many years. Lol
Going on three years and mine still looks like new. It's held up to oil spills, carb cleaner, down pipe heat ,rocks ,and more. So far ,so good.
Old Feb 24, 2019 | 02:08 PM
  #302
2006EvoIXer's Avatar
Yes, I was referring to trap doors not closing tight when I was thinking about leaks. I don't know if having 4 doors is better than 3 or 2. But it is absolutely better than none (oem)!
I may have asked it before but was too lazy to go back and read old posts. Lol
I need to work on my cars but am feeling lazy. Haha
Old Feb 24, 2019 | 02:12 PM
  #303
I will clean the grease off the hinges. One of my drap door was stuck wide open before I pulled it down for a picture.
Old Feb 24, 2019 | 02:13 PM
  #304
Is it just me or is the oem pan rusting? Is it not stainless steel?
Old Feb 24, 2019 | 02:22 PM
  #305
kaj's Avatar
kaj
They will get surface rust when exposed to air. Our oil pans are not stainless steel. That would kinda sweet, though.
Yes, when new and without oil in them, they don't always flop around. Also covered earlier in the thread and at the top of the Google doc I sent you guys. My pan is the same way. I ran the car until the oil was hot then dropped the pan to be sure they worked better. It was ****ing hot and I don't recommend it LOL
For my application, I wanted oil during acceleration and braking, as well as turning both ways. If someone was into drag racing I could see no real need for the rear hinges. Unfortunately, this pan was built for road racing.
Old Feb 24, 2019 | 02:31 PM
  #306
It is over built for my current needs but I may start racing in courses after I am satisfied with power output. Lol
i always like my things over built.
It gives me peace of mind.
Old Feb 24, 2019 | 02:50 PM
  #307
kaj's Avatar
kaj
At the very least, you now have an extra 2qts+ of oil and it will stay where it needs to be. Any turbo-charged car should have more than a 4qt sump, IMO, for anything more than daily driving. In fact, that's what started this whole thing: Matt was like, "Those cars only have a 4qt sump??". Now we have these LOL.
Old Feb 24, 2019 | 05:58 PM
  #308
OX's Avatar
OX
Whats a normal fill with the filter now?
Old Feb 24, 2019 | 07:29 PM
  #309
Sounds like 6 to 6.5 quarts now.
Old Feb 24, 2019 | 07:32 PM
  #310
kikiturbo's Avatar
Trap doors dont need to seal tight.. they are there to control the movement of the oil and keep what is left around the oil pickup. Also, remember that at 6000 rpm that pickup will pull 1 liter per second which in right hand turn will end up on the opposite side of the engine and this is where the extra capacity gives its benefits.
Kaj, great work on organizing the group buy, being the middleman is tough..
Old Feb 24, 2019 | 07:41 PM
  #311
kaj's Avatar
kaj
I keep adding from 1gal containers, until full. About 6.5qts, if I were to guess.
I learned my lesson the hard way. I'll be staying out of things, from now on. LOL
Unless someone comes up with an order for a ridiculous amount of money.
Old Feb 25, 2019 | 10:41 AM
  #312
LetsGetThisDone's Avatar
What was all the smoke at the end? I usually see black puffs if smoke from unburned fuel. Hope that wasn't coolant.
Turbo's pushing some oil, It happens. The car probably needs better crank case ventilation, or a scavenge pump for the turbo drains.
I believe I told you in this thread that you should have been charging for shipping and charging a bit extra to make some money for yourself lol. It sucks that probably one person ruined this to make you guys not want to do it anymore.
Old Feb 25, 2019 | 12:11 PM
  #313
kaj's Avatar
kaj
I did, but I didn't account for re shipping multiple pans back and forth.
To be fair. One of the problems was the shop's fault.
Old Jul 7, 2023 | 07:46 PM
  #314
AP's Avatar
AP
Can you tell me who built this oil pan? I wanted to buy a Race Fab pan but the wait time is long.
Old Jul 7, 2023 | 08:03 PM
  #315
kaj's Avatar
kaj
A guy I know had a shop that made them.
