Turbo Issues After New Motor
Old Sep 4, 2016 | 01:48 PM
Evo__Lee's Avatar
Sorry if this has already been discussed and resolved.
Here's the story and issue.
FP Black DBB MHI Housing works perfectly fine on Evo 8 stock block @27 psi with Gen 2 oil feed kit from OFH
New 2.4 build and FP black does not smoke at all on cold startup and up to 100 psi of oil pressure,
now once car gets warmed up to operating temps I'm seeing about 40 psi of oil pressure idling and the turbo then begins to smoke! What could my issue be?
i don't want to just feed my turbo to the cylinder head to see if it fixes the issue... Just want to here from others first with the same issue that is now resolved...
Old Sep 4, 2016 | 08:19 PM
Teal2nnr's Avatar
Does your oil line have a restricter in it? for a ball bearing turbo you don't want to have much more then 40-45 PSI at max RPM.
I run my turbo oil feed from the head. Haven't had any issues (on BB turbos anyway).
Old Sep 5, 2016 | 06:52 AM
Evo__Lee's Avatar
I have the FP Gen 2 kit that comes with everything... Now my new motor has balance shaft delete( using GSC shaft) and oil cooler deleted for now.. I'm seeing 40 psi at just idling! But the turbo has no shaft play and doesn't smoke on cold startups
Old Sep 18, 2016 | 11:37 AM
Ians06's Avatar
are you using the stock pcv system? Catch cans?
Old Sep 18, 2016 | 09:39 PM
LetsGetThisDone's Avatar
See the sticky thread in the section titled "crankcase pressure issues". And start reading....
8OhOh2
Jul 7, 2015 10:48 AM
mrm95
Apr 30, 2015 11:52 AM
fast03evo
Dec 1, 2013 01:06 PM
evonewb29
Jun 3, 2011 11:44 AM
blakevo8
Nov 7, 2005 07:24 PM
