hey guys, so I'm leaking which I believe is transmission fluid.
Pretty much where the orange bolt plus the other 2 on the left are leaking. I had the car running and saw oil dripping from there. Anyone know what may be leaking?
That was the only spot I saw dripping, but, I also saw oil on the transfer case. And somehow oil was on the top of the transmission and can be seen when the hood is up.
^what I wanted to ask. If so and if you are sure if it's trans or t case fluid, then separate the t case from trans and check the o rings on the t case and there is a small o ring on the t case that usually gets crushed, ripped or goes missing when wiggling the t case around when doing a clutch job. Or due to wear and tear it might be time to replace it.
Been super busy with work, haven't had time to check. Hopefully this weekend I can get around to actually checking the texture of the oil. I know so far that it only leaks when the engine is running. From what my uncle believes, could be the rear main seal. Gonna clean the area with brake cleaner, and hopefully can see exactly where it's coming from.
