Evo 8/9 Engine Failures
Old Jul 3, 2017 | 02:08 PM
  #46
TrendSetter's Avatar
op,
throw 400 to the wheels. then drive it a little while. then make 600. then maybe you can step it up to 700 and see how you like it.
you have no idea what you are getting into trying to make 1000 hp with any motor let alone a 4g63.
if you really want to make big power on a budget, learn to do all the work yourself. you make lots of power on cheap parts, labor is really expensive.
Old Jul 3, 2017 | 02:20 PM
  #47
kaj's Avatar
kaj
Originally Posted by 2006EvoIXer
I was thinking if it can handle 1000 hp (which should be 700-800 tq?), when cylinder runs lean, I'm hoping rods hold. Logs should show lean condition so I can check it out without a window in my block.
No on all of that.
You will never see that much torque.
Rods don't break due to lean conditions, Pistons do.
If you are dead set on an Evo with big power, please have someone build and tune it for you. Then have them explain all the maintenance you will need to do. And what to keep an eye on.
Do you own an Evo now?
How old are you?
Guess I'll do some digging for anyone who upgraded rods and pistons to see if it helped with anything.
It allows them to make more power.
Old Jul 3, 2017 | 02:40 PM
  #48
2006EvoIXer's Avatar
I have 430 now with stock motor and stock cams. It is really fun to drive. I'm just trying to keep it on the road by being prepared for a bad day since anything can destroy the engine. I went to a reputable shop for a complete timing belt change (with all the misc replacement parts) and trans fluid changes. I'll probably run this setup until next timing belt change. Then what do I do with high mileage motor?
I plan on doing as much as I can on my own because I like doing things myself, unless it is an install best left to professionals where anything can go wrong after the install (like timing belt).
I even think dealers are sloppy. Had them change timing belt on my Outlander for $1600+ and so many things were not put back right (filter box was open, only 1 plastic peg was holding each piece of underside on, etc). No way I went back to them with my evo. Lol
Originally Posted by TrendSetter
op,
Old Jul 3, 2017 | 02:50 PM
  #49
Looks like my next round of mods will be to make sure fuel and oil is always adequate.
Originally Posted by mrfred
The 4G63 is inherently capable of high power. The three things that kill these motors are 1) lack of sufficient fuel, 2) lack of sufficient oil, 3) Too much ignition timing. There are a number of ways for the first two conditions to occur. Here are a few that quickly come to mind:
Lack of fuel
- Insufficient capacity fuel system
- ****ty fuel system setup
- Not taking care of injectors
- Bad tune
Lack of oil
- Oil pan not up to the job
- Not paying attention to oil level
Too much timing obviously means a crappy tune.
Old Jul 3, 2017 | 06:14 PM
  #50
kaj's Avatar
kaj
Your fuel and oil are fine. If it ain't broke, don't fix it.
Old Jul 3, 2017 | 06:15 PM
  #51
kaj's Avatar
kaj
P.S. Never trust the dealership with an Evo.
Old Jul 3, 2017 | 06:36 PM
  #52
Erik@MIL.SPEC's Avatar
billet pistons are cut from forgings. all aftermarket pistons are forged.
These pistons are cut from a piece of billet aluminum. Most pistons are not. Quit being pedantic.
Old Jul 3, 2017 | 07:04 PM
  #53
mrfred's Avatar
Unfortunately, it really doesn't work like that. Detonation from running lean spikes cylinder pressures to many multiples of what happens during normal combustion. And greater heat is produced. Take care of fuel, oil, and ignition timing, and the motor should last if the parts were designed for the target power level. I guess I should mention that engine cooling matters as well, but most people who don't circuit race their Evo kill their motor by one of the items I mentioned.
Old Jul 3, 2017 | 08:51 PM
  #54
Good thing there's so many experienced people to save me money
Thanks for all the insights guys!
Old Jul 3, 2017 | 08:55 PM
  #55
This is ironic.
Old Jul 3, 2017 | 09:24 PM
  #56
kaj's Avatar
kaj
Never mind
Old Jul 3, 2017 | 09:45 PM
  #57
Never mind
The really good mechanics at dealerships usually move on to a specialty shop, so I agree that dealerships won't have the best evo mechanics. To cut on labor costs, they probably get all the new grads.
Old Jul 9, 2017 | 08:00 AM
  #58
845evo9's Avatar
Very true @2006evoixer
Old Jul 9, 2017 | 09:43 AM
  #59
barneyb's Avatar
Something to think about when dreaming of a 1000 hp engine.
The iconic American fighter plane of WWII, the P-51 Mustang, was powered by a Packard built British designed Merlin V-1650-9 that produced 1500 hp at 3000 rpm at 16,100 ft, fed by a two stage two speed blower running at 16 psi on 140 octane. This was thought to be the most the engine could withstand if it was to be reliable, bring back the pilot alive and make it to its 400 hour overhaul.
The equivalent power output for the Evo engine based on displacement is 111 hp.
fahad001
26
Nov 30, 2011 04:43 PM
mantella
May 29, 2009 11:54 PM
nothere
20
May 22, 2006 06:29 PM
