272/272 cam timing test and tune
Old Jan 10, 2006 | 09:39 PM
  #121
spoolinspyder's Avatar
With all this in mind, those of you who road tune using a standalone do these cams like conservative timng up top, We got only 91 here in CA so i figure a max of 17-19 degrees at the most.
Old Jan 11, 2006 | 05:23 PM
  #122
LpBevoEvo's Avatar
BUmp
Old Feb 10, 2006 | 11:09 PM
  #123
EVOlution561's Avatar
like umiami80 said it is the power that I am after and don't care about it idleing a little rougher. I got the hks 272's with aem gears
Old Mar 23, 2006 | 10:13 AM
  #124
Jeff_Jeske's Avatar
I am bumping this thread because I would like to discuss the +1/-1 settings that seem to be popular these days. Anyone done a comparison between the -4/-1 and the +1/-1?
I run -3/-3 for daily driving because I like the hard hitting low end. That combo moved max torque about 1k RPM lower than all other settings that I tried. I was unable to try +1/-1.
Old Mar 23, 2006 | 10:51 AM
  #125
Ted B's Avatar
The +1/-1 setting will deliver quicker and bigger low end and midrange than -3/-3, and probably won't sacrifice much of anything up top. My 280s at +2/0 spool quicker than my 272s did at -3/-3.
Old Mar 23, 2006 | 11:03 AM
  #126
trinydex's Avatar
haha are you gonna add this to yer sig too jeff?
Old Mar 23, 2006 | 02:40 PM
  #127
Jeff_Jeske's Avatar
Done!!!!
I may try those settings tonight.
Old Mar 23, 2006 | 03:23 PM
  #128
Ted B's Avatar
Let us know what you sense in the way of a difference.
Old Mar 31, 2006 | 08:45 AM
  #129
SSKILLA's Avatar
What about +1/-2. I don't care about my idle I knew about the roughness before I got the cams I just want big power wouldn't that set up give tli crazy bottom end and good mid range. Shouldn't kill topend too much right? I mean topend diference should be that noticable since my settings are 0/0 now right? Anyone?
Old Mar 31, 2006 | 10:11 AM
  #130
Ted B's Avatar
+1/-2 is going to be too tight a LSA IMO, and I'd expect the powerband to be short and peaky.
Old Mar 31, 2006 | 10:15 AM
  #131
SSKILLA's Avatar
What is LSA
Old Mar 31, 2006 | 10:18 AM
  #132
Ted B's Avatar
Lobe Separation Angle.
Old Mar 31, 2006 | 12:39 PM
  #133
hawjdude's Avatar
On my pump gas tune +2, 0 worked the best out of all the other cam gear timing.
Old May 11, 2006 | 10:12 PM
  #134
BJai02's Avatar
How does +1/-1 idle with 272's? I am at -4/-1.5 now with a very smooth idle. I tried -3/-3, but the car rumbles too much and it becomes a cop magnet.
Old May 12, 2006 | 12:48 AM
  #135
trinydex's Avatar
seperation is what causes smooth idle. apparently with 5 degrees of seperation your idle gets silkie smooth. so +1 and -1 will only be 2 degrees so your thump will still mostly be there.
