Official Blown Engine Thread
Old Sep 26, 2017 | 12:02 PM
Pal215's Avatar
Exclamation Official Blown Engine Thread
I have created this thread to simply share information, experiences, laughs, and knowledge based on ENGINE FAILURE ONLY. There will be ZERO tolerance for disrespect, making false claims, or name calling.
Please include pictures if possible as well as the year, mileage, modifications, power level, what happened, approximate date, solution, and why you think it happened.
To prevent total chaos, do NOT include your tuners name. This is not the thread for that.
I know there are A LOT of people on here who have blown their motor, so please contribute when you can .
Old Sep 26, 2017 | 12:03 PM
Pal215's Avatar
I'll go first:
Approximate Date: September 2014
Year: 2006
Mileage: 95,000
Modifications: Stock Block, Full bolt ons, Dual map tune E85/91
Power: 430hp/414trq
What Happened?: Started the car in the morning and engine idled rough, still drove it to work. I got on it three times on my way to work and it blew on the third. Number 3 piston rod decided it wasn't happy inside anymore.
Solution: Ordered an OEM used long block and dropped it in.
Why?: Autopsy suggests spun #3 rod bearing due to long oil change intervals. (Mobile-1, 10w30). Engine always had oil pressure.
Old Sep 26, 2017 | 12:11 PM
Biggiesacks's Avatar
I object that mobil 1 is a "low quality oil" and I believe you are violating your own rule about making false claims. It is well established that 400lbs of torque is pretty much riding the edge of what stock internals can handle, and without any additional facts I just don't see how you can come to the conclusion that it was the quality of the oil that led to your failure.
Old Sep 26, 2017 | 12:17 PM
Pal215's Avatar
Hey Biggie,
You're right and I apologize. Thanks for catching that for me
Corrected.
Old Sep 26, 2017 | 12:21 PM
thanks, much appreciated
and Im sorry for being "that guy", especially at the beginning of such a potentially important thread. I just believe in order for it to be so the data needs to be as empirical as possible.
Old Sep 26, 2017 | 12:28 PM
blackline's Avatar
5 Year Member
I'll go second:
Approximate Date: 9/23/2017
Year: 2004
Mileage: 127,000
Modifications: Stock Block, S2 cams, 1000CC injectors, CRBD BBK full port, 3in Turbo back,3.5in IC, 93 tune
Power: 341hp/304trq
What Happened?: hole in block.
Solution: In the processing of buying a built Map short block
Why?: 5th gear pull and lost oil pressure then BOOM( I wasn't driving, my friend was ;( )
Old Sep 26, 2017 | 12:33 PM
LetsGetThisDone's Avatar
Originally Posted by blackline
i'll go second:
Approximate date: 9/23/2017
year: 2004
mileage: 127,000
modifications: Stock block, s2 cams, 1000cc injectors, crbd bbk full port, 3in turbo back,3.5in ic, 93 tune
power: 341hp/304trq
what happened?: Hole in block.
solution: In the processing of buying a built map short block
why?: 5th gear pull and lost oil pressure then boom( i wasn't driving, my friend was ;( )
lol sttttaaahhhhhhhhhhppppppppppppppppppppppppppppp.
Old Sep 26, 2017 | 12:41 PM
blackline's Avatar
5 Year Member
that's what happened, lmao... I was tailing him in his stage 2 Audi(couldn't keep up) when I saw the smoke from the hood and exhaust my heart dropped ;(
Old Sep 26, 2017 | 12:43 PM
blackline's Avatar
5 Year Member
Old Sep 26, 2017 | 02:08 PM
Notice that I bolded your statement of buying a MAP short block. That is what I was telling you to stop.
Old Sep 26, 2017 | 03:05 PM
blackline's Avatar
5 Year Member
ohhhhhh I see. What’s wrong with MAP?
Old Sep 26, 2017 | 05:13 PM
Pal215's Avatar
See my build thread hahaha. Let's just say that we HIGHLY advise you to stick with English Racing or TsComptuned (If you can reach him).
Old Sep 26, 2017 | 06:44 PM
jlcann1's Avatar
This is just painful to read haha
Old Sep 27, 2017 | 11:23 AM
blackline's Avatar
5 Year Member
It sucks but it happens
Old Sep 27, 2017 | 04:11 PM
Pal215's Avatar
Yup, and the only positive thing we can do is learn from it and move on with our builds.
