Rough cost of reliable 500whp on fp red or black
Yea, but why pay money for a kit like that when you can just use a dual tune and be fine. Fuels trims can account for a pretty decent discrepancy in ethanol. How do you think a factory car can run 0% ethanol up to 10% ethanol without skipping a beat? The fuel trims are adjusting for the difference in specific gravity of the fuels.
I use a dual tune without any flex fuel kit, zero issues. When you want to change fuels, just wait until you've only got a couple gallons left and then fill up with the other stuff.
The way I see it, if you are going to run e85, you should test it every time you fill or have a ethanol content gauge. The gauge setups are $3-400 and the flex fuel setup is $600. Seems like a no brainer when you look at the benefits vs the cost.
^^ agree with the above. Folks should aim for simplicity and ease of mind if going this route and I believe ER also used to do the FiTronic stuff but maybe I remember it wrong now.
Just a heads up, carefully add up what you're going to spend on a stock frame. It very quickly qets over $3k. An ETS turbo kit with a 5558 can be had for just a tick over $4k, with a vband .82 hot side, it'll still spool around 4500 like an FP red.
Just make sure you weight your options carefully. Don't "assume" a stock frame setup will be cheaper, it's a little misleading because you can piece everything together.
As someone that had dual maps and went to flex fuel there are a few reasons. The first is that you no longer have to plan the fuel stops, you simply fill and go with whatever. Another reason the flex fuel is nice is that it adjusts timing, boost, and fuel tables for the ethanol content therefore giving you good power from whatever mix is in the car. For me though, the big reason is safety. I don't have to worry about getting a bad tank of e85 due to leftover winter blend or something else and having my motor let go because of it.
Testing it or having a gauge is a good idea, but you'll see an issue on your AFR gauge if you have a bad tank of fuel well before the engine lets go. IMO it's just a lot of money that doesn't need to be spent. I built my own content gauge for under $100, but before that the car ran on E85 blind for 5+ years without issue.
In some areas, ethanol content can vary from E50 to E83, so flex fuel is needed. It's no longer guaranteed E70 or better.
Also letsgetthisdone had a very solid point about stock frame vs a t3 kit earlier. I know that when I am done with my stock frame setup, I'll be very close to what a t3 kit costs. Now I wanted the stock look under the hood and preferred to keep the setup internally gated but if that isn't a concern of yours, a t3 kit should certainly be something to look at. I know that if I wasn't planning on doing some mexico racing, I would have went t3.
By no means am I saying to go pumping E85 all ***** nilly into your car thinking you're invincible. Flex fuel kits have their uses, if you desire them, but it's not a necessary piece to run a car on E85.
LGshow19
Evo X Dyno Results
18
Oct 25, 2014 08:43 AM
Graphic
Jun 16, 2012 11:45 PM
AustinB768
43
Jun 8, 2012 05:24 AM
