head build
Old Mar 18, 2018 | 07:07 PM
  #106
2006EvoIXer's Avatar
Because of you, I'm considering building my bottom end!
Old Mar 18, 2018 | 08:35 PM
  #107
nor11384's Avatar
FCOTM Winner
aw **** man sorry lol...eh, i thought about it since map is doing them for $2600 but then add shipping both ways...i said screw it...found out im going to be a dad again so cant do much to the car...wanted a turbo kit lol...
Old Mar 18, 2018 | 10:19 PM
  #108
Congrats! Family comes first....then our evos
Old Mar 19, 2018 | 08:11 AM
  #109
nor11384's Avatar
FCOTM Winner
Thx man. Yeah family first always. Daddy’s toys later lol...
Old Mar 19, 2018 | 08:36 PM
  #110
nor11384's Avatar
FCOTM Winner
Got the car running. It’s idling in the 11s. Rich as ****. I hooked up evoscan and it’s not reading fuel trims. I’m so frustrated...
Old Mar 19, 2018 | 08:42 PM
  #111
Did you connect all the wires? Maybe you missed a ground?
Old Mar 19, 2018 | 09:07 PM
  #112
nor11384's Avatar
FCOTM Winner
i connected everything...spent the whole night messing with this ****...just finished...car did this a couple months ago and threw in a used o2 sensor and after a whil started reading again...i dont think it was the o2 sensor idk...im so mad...
Old Mar 19, 2018 | 09:17 PM
  #113
This is a good time to call it a night (before you break something). Sleep on it and something could pop on your mind that could be the solution. I'll dig a bit to see if I can find anything.
Old Mar 19, 2018 | 09:23 PM
  #114
Try pulling off your fuel pump relay #3. It's possible that your relay is failing and giving full power.
Old Mar 19, 2018 | 09:29 PM
  #115
By pulling relay, your fuel pump will only get 8V
Old Mar 19, 2018 | 09:40 PM
  #116
nor11384's Avatar
FCOTM Winner
but how will that affect all of the fuel trims reading 0...also noticed oxygen feedback was at 0 i think...i logged it but forgot to save it...it was late and i was frustrated as all hell because everything came out awesome but this **** idling at 11s afr and then i hooked up the laptop and i just felt disgusted...i get so mad when i cant figure something out...
Old Mar 19, 2018 | 09:43 PM
  #117
don't know about the readings, but if your fuel pump is seeing 12V, your pump is overrunning your return line. Then fuel pressure at idle rises from 33 psi to 55ish.
Old Mar 19, 2018 | 09:50 PM
  #118
Just to be clear, don't drive your car without this relay. You won't have high boost fuel flows.
Old Mar 20, 2018 | 07:09 AM
  #119
nor11384's Avatar
FCOTM Winner
I checked fuel pressure at idle and it’s where it’s always been. With bigger cams should it be richer or leaner? Even still I wouldn’t see it changing this much maybe a point.
Old Mar 20, 2018 | 09:03 AM
  #120
It should be in closed loop once warmed up. During warm up, I read it's supposed to run lean at idle too. I can't verify because I wouldn't trust my UEGO readings until sensor warms up. But 11 at idle doesn't sound right.
