head build
Old Mar 20, 2018 | 09:06 AM
  #121
2006EvoIXer's Avatar
Are you on SD or MAF?
Old Mar 20, 2018 | 09:22 AM
  #122
nor11384's Avatar
FCOTM Winner
Sd no boost leaks just did a boost leak test...yeah I’ve had this problem before where fuel trims are at 0. Just started reading one day when a friend gave me a used o2 sensor.
Old Mar 20, 2018 | 09:28 AM
  #123
With SD, leaks shouldn't affect it. Have you tried swapping out the boost sensor to see if it's on it's way out?
Where is your SD sensor mounted?
Old Mar 20, 2018 | 10:53 AM
  #124
LetsGetThisDone's Avatar
Originally Posted by RightSaid fred
It's the valve springs trying to turn the cam gears which pulls on the tensioner.
That's why you turn the crank.
6 turns?
lol
4 stroke, 720 deg....2 turns.
2 turns lines up the cams and crank, I can't remember if its 4 or 6 turns of the crank to line up the balance shafts.
Old Mar 20, 2018 | 11:03 AM
  #125
nor11384's Avatar
FCOTM Winner
i just did it...if youre at tdc and turn 3 times itll line up the crank and balance shafts but cam gears will be with dowels facing down...3 more turns everything will line up...
SmurfZilla
Jan 21, 2011 08:57 PM
SmurfZilla
Jan 19, 2011 06:54 AM
WickedIXMR
67
Mar 13, 2009 01:43 PM
turboj
19
Aug 9, 2007 11:26 AM
djskyy
13
Jun 11, 2006 10:21 AM
