"It Detonated"
Old Mar 14, 2018 | 05:29 PM
  #76
2006EvoIXer's Avatar
With the final tunes, do all AFRs slowly drop?
Old Mar 14, 2018 | 05:30 PM
  #77
Big_Mike1's Avatar
Originally Posted by Teal2nnr
Not sure the point in protecting a shop that screwed up your car. If that's in fact what happened of course. Sorry for your bad luck. I would be very interested in seeing your timing and fuel map.
not trying to start grief..
Old Mar 14, 2018 | 06:12 PM
  #78
Big_Mike1's Avatar
Old Mar 14, 2018 | 06:13 PM
  #79
Big_Mike1's Avatar
this was a revivsed map the day after the dyno tune I do not have a file of the original tune.
Old Mar 14, 2018 | 06:30 PM
  #80
Look at the high end load!
Any mistakes would have been over written on the same day.
check out my original tune and leaner tune to help my turbo spool up faster on 91 octane gas.
Old Mar 14, 2018 | 06:45 PM
  #81
Big_Mike1's Avatar
problem with E85 is it really doesn't knock. You could have just been running too much timing for the RPM/boost level in your map and just damaged it by igniting past MBT.
regardless the cel flash for knock was turned off just checked
Old Mar 14, 2018 | 07:27 PM
  #82
Evo8775's Avatar
Sad to see that happen. In my experience I would definitely take the car to a differnt tuner. Hope everything goes well with your next build
Old Mar 14, 2018 | 08:47 PM
  #83
Agreed. That high octane AFR map is a complete joke. Look how conservative he made it! 10.0 AFR on E85 is a joke. I recall that many tuners aim for 12.0 because it is ethanol. 10.0 is even more conservative than 91 octane gas which is 11.5. He is doing his best to cover his tracks but does he know you recorded him during tune?
Old Mar 14, 2018 | 09:46 PM
  #84
Big_Mike1's Avatar
maybe idk I was standing behind the car while he was in the car tuning
Old Mar 14, 2018 | 11:26 PM
  #85
KonosP's Avatar
Veteran: Army
Man that sucks, I hope it works out for you in the end man.
This is the kind of thing that keeps my cautious when thinking about a mod that would require a tune afterwards
Old Mar 15, 2018 | 06:18 AM
  #86
Biggiesacks's Avatar
you can't look at AFR numbers in the map as if thats what the car is actually going to run, they are just values. I have 9's in my fuel map and thats what it takes in those load/rpm cells to get the 12.0 AFR that i want. They are not meant to be a 1:1.
Old Mar 15, 2018 | 08:42 AM
  #87
blackline's Avatar
5 Year Member
Sorry to hear about that Mike, I've went thought the same issue 6 months ago when my engine went to hell so I know the **** you're going through right now. I finally finished my build last weekend(everything new ).
Old Mar 15, 2018 | 08:53 AM
  #88
LetsGetThisDone's Avatar
I'm really starting to think you don't know what you're talking about. The Fuel and timing maps look fine. Hards say for sure on timing without know what load is what hitting around peak torque, but it's fine out the top. AFR never matches what is in the fuel map, as fueling is a calculation based on whats in that map, the SD programming, Injector scaling, and MAF scaling. You could max the map out rich at 7.4, but make injector scaling 6000 and the car would still run lean.
Old Mar 15, 2018 | 08:54 AM
  #89
This makes sense. I was wondering if these were for closed loop (which didn't make sense). Thank for explaining!
Old Mar 15, 2018 | 08:58 AM
  #90
You're right. This is new to me. I've started logging and sending logs to my tuner to adjust for cold nights. I only load the changes and don't touch the maps since this blows engines.
