View Poll Results: HKS Cams
272intake \\ 264 exhaust
61
30.81%
264intake \\ 272 exhaust
137
69.19%
Voters: 198. You may not vote on this poll
HKS CAMS 272i/264e or 264i/272e?
Originally Posted by Soon2BEVO
Well you stated no where you made comparisons so I really couldnt have known that. You only stated the time you ran with a paticular set-up.
So you like the 272/264 combo best? I read the article AMS did on the cams, seemed my favorite was the straight 264s. The straight 272s had 7ft/lb less tq and just +1hp. I want to have MAXIMUM torque. Was your time of 11.8@117 on race gas or pump and what boost? That is a good trap speed.
I liked it, but I couldn't really tell a huge difference between any of the cam combos. The air temp had a more dramatic affect than the cams I had installed.
I also ran 118.02mph on the straight 264s, but that was an exceptionally cold day. It was in the 30s. It was 68 degrees when I ran the 117.55mph run.That pass was on race gas. I ran a 30psi spike after a shift, and boost fell to around 24 to 25psi at redline.
On the 118.02mph day, it was cold enough that I could hold 26psi to redline with the straight 264s.
Originally Posted by ShapeGSX
They never did try the 272I/264E combo, though.
cams
IF you go with the staggered setup of 264in and 272 ex, it would be wise to get cam gears to dial it in right. the 272 on exhaust side will help the spool, the 264 on the intake side could then be sync in with the 272 using ur cam gears to maximize the mid to high end powerband. you should also look into getting a intake maifold we are testing one now and it should yeild 40 whp and with larger throttlebody yeild atleast 60whp. Will let you know once the dyno tests are done. if it works all those that want one can pm me to get it.
There isn't much difference between the 264/272 and 272/264 because the overlap is all the same. The only other significant difference between them is the difference in point of the intake valve closing, and that apparently amounts to peanuts in a real world setting.
With the split setup, installing both cams on the same lobe centers (e.g. -3/-3) is a safe bet. One can play with settings such as -4/-1 or -4/-2, and the differences should be roughly equivalent to the same with the 272 set (a little later spool, a few more peak hp).
As for 'EVO Voodo's post, I am very doubtful of 40whp from an intake manifold swap, and even more so of an extra 20whp from a TB change, simply because there are cars running into the limits of the factory turbo without those items. So to that I say 'good luck' and we await your results.
I am very happy with my 272i/264e combo. my car spools up faster than my bro who is running straight 264's. Even if straight 264's have more torque, I still beat him in the 60f mark and top speed at the track. we both have practically the same mods. the main dif is he has a JIC 3.25 cat back and I have the HKS 3 in catback. ohh and I have the hks suction kit and he has an RMR intake.
Why does everyone listen to people that have no experience or no track results and use thier word as magic? I know a number of guys that DO have lots of track results hitting in the 10's and they are all using 272/272. Of course these are cars designed for the track... if you really give a crap about a GREAT idle and 3 HP on the bottom then get 264/272. If you dont plan on upgrading much get 264/264 but I dont think that setup would be worth the 6 bills and the labor to put em in.
600 plus the labor to do it... 30 is a good amount but I think normally people that get that much out of them are adjusting the timing with gears... I could be wrong though. I would rather use 272/272 personally.. thats what I got and I like it
To each his own I guess.
soon2, I believe Trina is talking about 264s yielding 30hp gains with adjustable gears not just the gears alone.
Trina.. I have to ask you about the 10s with HKS 272s. Would you please share what the supporting mod.s are that allow such ETs with these cams. Also what do you like the best about your own set up with 272s?
Originally Posted by -EV1L 8-
they sell their CAMS seperatly, they dont sell them as a package...you choose the setup u want.... Thats y i asked for expereinced or expert advice......u must not know a lot about cams... go to Road Rage Engineering and read what they say about the cam setup then go to a real aftermarket car shop and they will tell u the exact opposite......If i go with experimenting on my car worst case senario it would be not as bad as getting a set of 272's cuz some people are having crappy idling
Just go straight 272's they work great.
Originally Posted by Quickshift
Wouldnt it be redundent to have more flow on the intake side than the exhaust side which pushes the turbo? More flow is what turbo cars are all about. You would be restricting some of the flow by inducing a smaller exhaust profile of the cams. Just think about a funnel the top you got your intake and the bottom is the exhaust as it flows through , the inlet gets enough air but the exhaust port can only let so much through. I would think that by doing it with that config 272i 262e you would also get some overheating issues as well. I could see maybe a small gain in torque but the hp would be hurt in the process.
I would say call AMS and ask them, they have tried many combos on their dyno.
Originally Posted by crazyevoRS
JUN and HKS have similar specs ( lift and duration) but the JUNs pull like a **** compared to the HKS.
Originally Posted by mlevo
do you mean on the stock turbo can pull out that much whp with 264s cam setup?
