Evo IX trouble firing up, bad clicking
Old Mar 7, 2020 | 11:04 AM
LakerRaider's Avatar
Hey everyone, My evo 9 is having trouble fully firing up, has some bad clicking... but I can’t pin down an issue. Video is below, you can see as I try to give it some gas too. Checked battery, fuses for engine/ignition/fuel pump, coils, and spark plugs...they are good. Nothing looks out of place. Log is attached. A week before this issue, out of the blue the car would cut out under acceleration and got progressively worse over a few miles. Ordered a new Omni 4 bar and that solved the issue as the car completely returned to normal and I went on my way boosting 35psi multiple times with no issue. One day later, can’t get the car to fire up. Prior to this, no issues for years. Ideas?
Stock block, E85, FIC 1250cc, dual walbro 250cc, cosworth 272s , headstuds , new omni 4bar map sensor, mhi FP Black, tial Q, speed density, ported manifolds and TB, ETS intercooler and piping, etc. HELP!
thanks for the help!
Old Mar 7, 2020 | 05:53 PM
hutch959's Avatar
id pull the valve cover off and see whats going on in there.
Old Mar 8, 2020 | 11:46 AM
evo420's Avatar
Wowzers. Yeah you definitely don’t want to start that! Start with checking timing. But it’s time for a new motor I would say.
Old Mar 14, 2020 | 10:13 AM
Doesn’t sound like a fuel related issue to anyone???
Old Mar 14, 2020 | 12:14 PM
LetsGetThisDone's Avatar
No, it sounds like a ****s broken issue.
Old Mar 14, 2020 | 01:36 PM
Biggiesacks's Avatar
dude! check your timing marks before doing anything else.
Old Mar 15, 2020 | 06:35 PM
It’s just crazy because there were no symptoms at all prior to this. Pulled hard and perfect for years. No weird noises, etc. turn it off one day, then this. Can looking at the log rule anything out?
Old Mar 15, 2020 | 08:06 PM
Your symptoms seem pretty consistent with a timing belt related failure, which is why I was saying to check your timing marks.
Old Mar 17, 2020 | 10:43 AM
240Z TwinTurbo's Avatar
Had a clacking like that late last year, which I swore came from the MIVEC gear. Turns out the timing belt tensioner took a dump and had ejected its grease and belt was slapping something. Had the same issue on my wife's Honda Odyssey with a bad tensioner and the clacking noise. In the case of the Honda, the tensioner didn't eject the grease so externally it looked fine, but when I pulled it out the hydraulic pin had movement. Don't run the car and pull off the upper and lower timing covers to check the timing marks as well as the tensioner.
VanduzerWilliam
11
Mar 14, 2019 05:42 PM
turbocheese
Apr 13, 2016 11:08 PM
Revoluzion
Aug 23, 2015 12:59 AM
hooliganSKATE
Aug 17, 2015 03:30 PM
Midnightevo8
May 6, 2015 10:08 AM
