Clutch recommendation help
Old May 8, 2020 | 01:40 PM
LetsGetThisDone's Avatar
Can confirm, the mivec 2.2/red combo in ethanol hits ridiculously hard. My car had 500wtq at around 4000.
Old May 8, 2020 | 04:03 PM
240Z TwinTurbo's Avatar
Originally Posted by Abacus
I know you've had great luck with that clutch and what its rated for. But I didn't have the same outcome.
I ran the 6 puck/HD plate with the 4.11 final drive at 400-450ft lbs. With a proper 300-500 mile breakin ( stop and go) the entire face of the pucks had a chance to bed properly it was ok. Pretty happy with it at that point.
Now, my 10:1 2.2 MHI red hits like a hammer and will make 480-500 lb ft around 4000-4400 Comparing it to your setup my car is a different animal at 4000 with the red, E85 and proper timing. It snaps on. The clutch in this case is the fuse.
Once I broke in the next 6 puck then ran it harder it was toast at 3K miles. I believe the taller final drive is a factor and the small hard hitting turbo on proper timing is a large factor. I do drive this car very hard but its not launched often. With the setup I had I would run 28-32psi in first and second with very little or no wheelspin.
I moved into the exedy twin for more surface area to handle the power.
Thanks for the response and I was not doubting you, but was actually curious because I am currently changing my setup. Starting the S366 SX-E (6668) tomorrow so I expect more torque, but I also ordered a 4.08 final drive from Jack so I have been debating whether I need a clutch change. I just don't have any issues with the clutch and it grabs hard, but I don't want to pull the tranny twice if there is an issue. Decisions Decisions!
asu11
Feb 5, 2014 05:18 AM
mrevoix2006
May 18, 2011 12:38 PM
EvoDan2004
37
Nov 29, 2006 07:51 AM
TwStDeVo
May 22, 2006 12:07 PM
Massevo8
30
Jul 18, 2005 05:51 PM
