Weird whistling noise ,what is it?
Old Mar 23, 2021 | 04:46 AM
astro black's Avatar
Hi guys
Yesterday happened the thing first.. i attached video about for the better explaining. On higher speed and higher boost, i realized whistling noise from the engine bay belt area or behind the dashboard front of pessenger seat.
Video:
Any ideas what is it? Really similar when the wind is whistling somewhere. Or small birds in the nest. I thinked that its the belt but today i drove 30kms without this problem , i drove the same style homeward maybe a little more pulls because of the traffic overtakings and it has come again.
Old Mar 23, 2021 | 06:26 AM
@astro black
  • Possible boost leak?
  • Make sure your windows are fully seated up. Had that happen to me once.
Maybe youre right & could be belt related? Nice Vid / Thanks
Old Mar 23, 2021 | 04:28 PM
hutch959's Avatar
stock turbo with some mileage on it?
i had a stock turbo that started making a whistle noise...
replaced it.
Old Mar 24, 2021 | 01:31 AM
replaced it.
Nope its not stock, the car is Evo 8 , and it has the upgraded "evo 9 type" turbo supported around 380-400hp. Milage is only 51.000 miles in the car.
Old Mar 24, 2021 | 04:16 PM
hutch959's Avatar
but its a stock evo 9 turbo
anyway.... stock frame.... no BB
anyway... thats low mileage but could still be the turbo
Old Mar 24, 2021 | 06:18 PM
fafaforza's Avatar
Doesn't seem to be affected by engine speed.
Seems to be affected by your road speed.
So maybe something is positioned in such a way as to make a whistling noise from the passing air. Maybe cover one side of the car with plastic or something, see if it goes away, do the same to the other side. Isolate it until you find it.
Old Mar 25, 2021 | 03:33 AM
its a JM Turbo tech named turbo ,on the car, i bought with it i dont know when they changed to it. I searched about the part number and its a td05h: https://www.jmturbo.com/component/es...brand-new.html
Old Mar 25, 2021 | 03:37 AM
while i increase the speed of the car, i increase the rpms too so it kinda the same thing, maybe the video isnt proper for totally explain this.
And the most annoying thing is that its not an always present sound. Last time i drove 30-40kilometers without noise before its happened again.
Old Mar 28, 2021 | 08:19 AM
fafaforza's Avatar
Originally Posted by astro black
while i increase the speed of the car, i increase the rpms too so it kinda the same thing, maybe the video isnt proper for totally explain this..
Pull the clutch in and let the revs drop while maintaining more or less the same speed. AFAIK, only in a CVT does RPM not change with the car accelerating. Even automatics shift
egg_baLLa
Jun 7, 2019 12:21 PM
Rocketkev
Lancer Troubleshooting
Mar 7, 2017 03:57 PM
ali911
Feb 27, 2017 09:43 PM
dragon831
Apr 18, 2014 01:43 PM
evodrivesme
May 22, 2012 06:36 AM
