is $75 good for a 0s simulator for the cat?
Old Apr 16, 2004 | 05:03 PM
XRS-Lift's Avatar
is $75 good for a o2 simulator for the cat?
im having a shop punch out my cat and put a o2 simulator in to avoid a check engine light, is $75 a good deal on the simulator and its install? not including hollowing the cat.
Old Apr 16, 2004 | 05:22 PM
chrisw's Avatar
Why not spend the $140 and buy a high flow cat?
I found this with a quick google search...
http://www.lmperformance.com/2900/20.html
Old Apr 16, 2004 | 07:36 PM
Buckkaaaa!!'s Avatar
you should be able to pick up a simulator for around 40 bucks
Old Apr 17, 2004 | 10:58 AM
XRS-Lift's Avatar
i have an ultimate racing 3'' highflow cat. Im gonna punch it out. If i punch out the stock cat the flange would still only be 2.5 inches or whatever the stock pipe is.
40 bucks for a simulator? Where?
Old Apr 17, 2004 | 11:00 AM
DocMortal's Avatar
www.buschurracing.com sells them for 45 i believe but you have to call.........
Old Apr 17, 2004 | 11:10 AM
bishiboy's Avatar
BPClements told me he took some spark plug anti-foulers, found in the help section of Pep Boys. He drilled a 1/2 hole on each one (he used two). Threaded the O2 sensor into them and install in exhaust. Hasn't got a CEL in over 500 miles. Cost less than $10.
It's the same theory as a deeper O2 bung, takes the sensor out of the direct exhaust flow.
Old Apr 17, 2004 | 01:34 PM
XRS-Lift's Avatar
thanks for the info guys.
Old Apr 18, 2004 | 06:43 PM
Z1 Performance's Avatar
Why nto jsut buy the Ultimate Racing test pipe for $70.00, and have the best of all worlds? A high flow cat for street, a race pipe for track days, or drag days, etc, and NO CE light at all
Adam
Old Apr 18, 2004 | 06:45 PM
en1gma19's Avatar
Adam
As usual, Adam beat me to it...
Old Apr 19, 2004 | 10:50 AM
USP45's Avatar
I did the drilling out of the spark plug anti-fouler and it works great. No more CEL.
Old Apr 19, 2004 | 11:16 AM
XRS-Lift's Avatar
can someone do a how to on this? im sure I and the rest of the forum would really appretiate it.
Old Apr 19, 2004 | 11:17 AM
XRS-Lift's Avatar
Adam
yeah but if u punch out a highflow cat, u can have the power of a testpipe ALL the time without having to switch.
Old Apr 19, 2004 | 03:01 PM
marksae's Avatar
Don't punch out a perfectly good cat. Those will come in handy come smog check time. Get one of these!
http://www.roadraceengineering.com/p...nator-side.JPG
http://www.roadraceengineering.com/p...or-through.JPG
ug_orf
Feb 19, 2016 09:26 AM
Vivid Racing
Jun 22, 2010 11:45 AM
SuperStreet2K6
41
Jun 28, 2007 02:07 AM
use2vtec
26
Mar 21, 2006 09:57 PM
zstryder
25
May 27, 2004 01:21 PM
