Spark Plugs / Sputtering / Oil Found
Old Jul 26, 2022 | 01:57 PM
  #31
bcollins92's Avatar
Your compression is good and if the intercooler piping doesnt have oil in it, we can rule out the turbo/ too much crank case pressure. I would say your valve stem seals are bad.
Old Jul 26, 2022 | 02:02 PM
  #32
LetsGetThisDone's Avatar
Originally Posted by sasha1712
Is that 0.20mm?
Originally Posted by Smoknzx3
yes
No. .200mm is .008". Sparkplug gap is .020"
Hi
just done a compression test. Not sure what the figures should be?
cheers
Compression is fine for cold engine.
Old Jul 26, 2022 | 02:06 PM
  #33
sasha1712's Avatar
so it should be 0.020” equals 0.50mm?
Old Jul 27, 2022 | 01:44 PM
  #34
Evoryder's Avatar
Compression test; did you add oil to see if the numbers increased ?
Old Jul 27, 2022 | 06:30 PM
  #35
hiboost2.0's Avatar
evoryder and letsgetthisdone are on the right track.
what cylinders look like that? do they share an ignition coil? Those are definitely badly oil fouled. Valve stem seals are likely. if you have a boroscope you can peek into the cylinder with it and look at the piston walls to see if they are gouged. I doubt it though due to your compression numbers.
Valve stem seals are likely and typically will leak oil into the combustion chamber when the engine is off as the oil drains back down to the pan. A key indicator when they fail is blue smoke at start up that clears up when the car gets warm. bad stem seals will not show up with leakdown/compression test.
Old Jul 27, 2022 | 10:40 PM
  #36
sasha1712's Avatar
cylinders 1 and 2 have a little bit of oil sat in top of the cylinder. I did borescope and couldn’t see anything obvious with the cylinder walls. As for blue smoke, there is a little on startup, so from what your saying, there’s my issue?
many thanks
Old Jul 28, 2022 | 01:40 AM
  #37
Jonno99's Avatar
Leak down test
Old Jul 28, 2022 | 01:42 AM
  #38
sasha1712's Avatar
nope. Will try that. Cheers
Old Jul 28, 2022 | 01:47 AM
  #39
sasha1712's Avatar
Originally Posted by Jonno99
Leak down test
Going off what has been said above, that won’t show if stem seals are passing?
cheers
Old Jul 28, 2022 | 10:12 AM
  #40
Evoryder's Avatar
Does it smoke when you were under WOT? Hopefully it's the valve stems and not the oil piston ring failure. Let us know how it goes with the new plugs in.
Old Jul 28, 2022 | 12:37 PM
  #41
sasha1712's Avatar
I can’t say as I’ve noticed tbh. I’ve read there’s a tool that allows the seals to be replaced with the head in situe?
Old Jul 28, 2022 | 01:51 PM
  #42
Evoryder's Avatar
Yes, something like this.
https://www.euroexportinc.com/mitsub...alve-seal-kit/
Mevolution03
Mar 3, 2011 11:13 AM
polish_pounder
17
Jan 30, 2011 10:24 AM
jude
39
Jan 23, 2008 06:25 AM
chaz517
Jun 15, 2007 06:08 PM
jade
Feb 1, 2006 12:57 AM
