Crank case pressure oil leak
Old Jan 14, 2023 | 06:26 PM
thepoint4life23's Avatar
Thanks,
Going to change the dip stick o rings and hope its not the main seal behind the timing cover!
Old Jan 14, 2023 | 08:26 PM
LetsGetThisDone's Avatar
Even if that is leaking, it's not from crankcase pressure.
Old Jan 16, 2023 | 09:29 AM
I get that now. Is it common for Leaks to only happen under load?
Old Jan 16, 2023 | 11:24 AM
99.9% of the time it's the dipstick leaking when that happens.
Old Jan 16, 2023 | 01:51 PM
Jp7's Avatar
Jp7
Now that my car is gone- this is sort of a moot point, but if I had it all to do again: One of the things I would have done was install a crankcase "PSI" gauge so I could monitor what is going on down there. The kicker is I had a spot I wanted to use when I did my shift console gauge pod and I poorly decided to only use one spot when I should have done a second. I think a 0-10 PSI gauge would have been perfect. If there is any more than 1PSI the seals are NOT designed to hold that back.
Old Mar 6, 2024 | 07:36 AM
I think part of my issue is that i have a vented dip stick tube with a filter on it and seems to spray oil out that filter. Working on getting a stock tube now.
Old Mar 6, 2024 | 10:04 AM
ViciousLSD's Avatar
i use that to return oil, not to vent pressure
curtisb
11
Mar 22, 2014 07:31 AM
evokyle
Feb 15, 2011 01:54 PM
flyguycfi
Jul 21, 2009 03:27 AM
mxjs
Jun 19, 2006 02:16 AM
