Weird clutch issue
Old Mar 16, 2023 | 04:46 PM
Berettadan's Avatar
Weird clutch issue
So I replaced my clutch in my evo 9 installed an act lightened flywheel, hd pressure plate and a street disc. Install was straight forward everything seemed to go fine. Went to drive the car it felt different a little harder to get into gear. So I went through the clutch adjustment procedure and it seemed to help. And I installed oem oil. If I’m coming to rolling stop it’s fine it’s only after a dead stop or coming from neutral. I put all 4 wheels off the ground to check for dragging. Put it in 1st pressed in clutch pedal and reved it to limiter and it’s not dragging . What I found is if I press the clutch pedal in for about 4 seconds before I put it in gear it slides right in. Haven’t had a chance to bleed slave yet but dont see how air would have gotten in. Any input would be great thanks
Old Mar 17, 2023 | 07:18 AM
240Z TwinTurbo's Avatar
Did you wire brush the splines on the trans and apply the lube prior to installing the disk?
evoforstevo
Jul 21, 2017 05:07 PM
evo2pwr
Apr 9, 2017 05:15 AM
silverevo05
Jan 11, 2014 12:31 PM
MN_Evolution
Oct 4, 2010 02:40 AM
evo_q8
10
Dec 11, 2009 10:28 PM
