Evo 9 Problem
Old Mar 24, 2024 | 09:42 PM
beast66's Avatar
Evo 9 Problem
So I have been trying to troubleshoot my car. Ive been having a sputtering issue when I try to push the car. I dont know what it can be. I had recently done an oil change, changed the plugs, put fresh gas in it, and I installed a new oil pressure sensor because the old one was leaking. Anyone have any idea as to what it can be? I did a boost leak test just to make sure but I have been building good boost. I am running a Forge RS bov and a forge wastegate. Any help would be appreciated. Thanks!
File Type: mov
Old Mar 24, 2024 | 09:54 PM
RallySport9's Avatar
Im thinking it could be fuel pressure loss.You have an afr gauge to give some numbers?
Old Mar 24, 2024 | 10:04 PM
beast66's Avatar
i attached a video of the afr
File Type: mov
Old Mar 24, 2024 | 10:09 PM
hmm all I see is an audio file I hear the sound..
Old Mar 24, 2024 | 10:12 PM
beast66's Avatar
the afr shoots all the way to 10
Old Mar 25, 2024 | 09:56 AM
schuhie's Avatar
Looks to me like its probably rich and that might be causing your issues.
Is the AFR 10 when its stuttering?
Do you have a way to log the car for knock, AFR, timing, etc?
Is the car tuned?
Old Mar 27, 2024 | 03:40 PM
varv's Avatar
This is normal if the car is tuned that way. My goes to 8 AFR when I push it hard.
Old Mar 27, 2024 | 05:24 PM
beast66's Avatar
My afr has always been like that when I go. It sputters up on high rpm so Im not sure if I should start by checking the fuel filter or checking injectors
Old Apr 3, 2024 | 12:49 PM
wht95scort's Avatar
What are the plugs gapped to?
k20toEVO
18
Sep 8, 2010 01:02 PM
Chris Moore
Apr 7, 2010 06:21 AM
drewblueeye
Jan 17, 2007 02:55 PM
healthynine
Jul 31, 2006 08:19 PM
EVO8LTW
Mar 27, 2006 09:02 AM
