Random Misfire 0300: Dealership reflash available...
Old Oct 28, 2007 | 11:49 AM
  #571
KazzEvo8's Avatar
Originally Posted by mitsuorder
I have 107k miles on my car. Just did the clutch at 105k. I have literally up until the day after the clutch install thrown the p0300 code once in all of my miles. I replaced the clutch with the exact same one as I did before with the only difference being that I used a full weight stock flywheel this time around instead of my previous lightened stocker. New transmission is simply not an option right now and I have no chance in hell to have anything warrantied. I am going to attempt to disconnect the drive shaft from it's mid point rotate it, and then reconnect it. Reason being is that I did not, for some unknown reason to me, mark the position of the shaft at that point when removing it and believe that it being out of orientation may be causing it to be out of balance, causing the resonance.
Opinions on my theory?
Josh
Opinion? No. Intrigued at your results? Hell yes!
Old Nov 8, 2007 | 12:57 AM
  #572
Evo_SpeedKing's Avatar
so let me ask you this...how tight do you turn your gas cap? it might sound stupid and be just a coincidence, but i kept noticing i would get the P300 towards the bottom of my tank of fuel and i never cranked on the gas cap. once i started really clicking it, no p300 for months, then this last tank i forgot to tighten it and BAM guess what came back today?
i'm at the end of my tank, my walbro is whining and it happened after i was in 5th, wot and had to get off the gas and back on real quick to avoid some jacka$$ coming into my lane.
what do you think? coincidence?
Old Mar 24, 2012 | 08:56 AM
  #573
skaterdude888's Avatar
Does anyone know if you can read the codes that the TSB needs you to read using ECUFlash? Can it be reflashed using this program? anyone have any luck on it?
Old Mar 24, 2012 | 10:24 AM
  #574
gsrboi80's Avatar
Evoscan or Scan Tech OBDII can pull the codes. Or any simple OBDII handheld
Old Mar 24, 2012 | 06:46 PM
  #575
yellaevo's Avatar
Is this for all years or no? How much if you aren't under warranty??
Old Mar 24, 2012 | 06:54 PM
  #576
mt057's Avatar
Back from the dead...
We now have a p0300 disable that any tuner can flash to your ecu. This seems to plague the Evo 8 more than the Evo 9
Old Mar 24, 2012 | 10:18 PM
  #577
barneyb's Avatar
I'm not going to read all through this thread to see what people found the success of the reflash was. I've had it and the bottom line is that the reflash offered by the dealer does not work. Do as in the post above.
barneyb
Feb 28, 2017 07:18 PM
DJErickG
Feb 11, 2015 05:57 PM
ftlvwrx
Pacific Northwest
Sep 15, 2013 02:10 PM
usernameinuse
Dec 13, 2010 01:26 PM
Poondoggs
Nov 6, 2009 04:15 AM
