Random Misfire 0300: Dealership reflash available...
Old Mar 22, 2005 | 11:11 AM
  #421
MYFIRSTEVO's Avatar
my question is...is this p0300 vibrating issue will harm the motor or the car? or will it just annoy the hell out of everyone including myself?
Old Mar 22, 2005 | 11:15 AM
  #422
webguy330i's Avatar
I don't think anyone knows the answer to this for sure. It sure as hell is annoying, and it seems that it would be detrimental over time, but there's no evidence confirming that.
Old Mar 22, 2005 | 11:16 AM
  #423
MYFIRSTEVO's Avatar
this is why i'm starting to hate my car!!!!
Old Mar 22, 2005 | 04:56 PM
  #424
webguy330i's Avatar
Join the club. =/
Old Mar 22, 2005 | 06:05 PM
  #425
chrisw's Avatar
Originally Posted by Cr0mster
If you ask me this still sucks. So they dropped the correction to 10 cycles instead of 20. There is still a problem with our cars. They should not be stumbling and its happening on so many Evos that it's a legit problem that needs to be fixed.
I got my ECU reflashed, I still have the stumble... But unlike you, I am not worried. My car is not even close to stock at this point so I could have other issues that could cause the misfiring (lightweight flywheel comes to mind )
Old Mar 23, 2005 | 01:34 PM
  #426
MYFIRSTEVO's Avatar
ok...I got my car reflashed as well, but what I want to know is... what did they actually change? is the base map still the same? I got safc, should I be worry about retuning the car?
help please
Old Mar 23, 2005 | 02:09 PM
  #427
Option2's Avatar
You shouldn't have to retune at all.
Old Mar 23, 2005 | 02:23 PM
  #428
MYFIRSTEVO's Avatar
What makes you say that? not that i'm against you.. .just wondering if you know more info than whats out there... =)
thanks
Old Mar 23, 2005 | 02:52 PM
  #429
Option2's Avatar
From what I understand, the new flash is just allowing the ECU more "fudge factor" before throwing a P0300. The program from the factory is so sensitive that it is picking up harmonics generated from the drivetrain and interpreting it as knock.
Old Mar 23, 2005 | 02:58 PM
  #430
Volunteer's Avatar
If you let the dealership reflash you ecu for the random mifire don't count on anyone tuning your ecu, Mitsu will lock it out. I'm fighting that battle right now trying to get my ecu flashed back to the old revision. Tried to get Shiv to Xflash my ecu and he could not do anything with it since Mitsu flashed it. Now I'm screwed unless I can 1 get another ecu out of a another car. or two get Mitsu to reverse the flash to the old version. Sucks to be me.
Old Mar 23, 2005 | 03:02 PM
  #431
chrisw's Avatar
I was told the same.
Old Mar 23, 2005 | 03:09 PM
  #432
MYFIRSTEVO's Avatar
see you guys are talking about tune with a flash, I was referring to SAFC tune. do you guys think that I should retune it or not?
Old Mar 24, 2005 | 09:15 AM
  #433
Option2's Avatar
I'm stating the reason why you shouldn't have to retune your SAFC. The fuel/ignition maps have not changed. Just the sensitivity of the knock sensor.
Old Mar 24, 2005 | 09:32 AM
  #434
Zampolit's Avatar
I don't know how to do a poll but after studying my car and my buddies (we both have evo 8's, mine is 03 and his is 04) we were both throughing p0300 codes avery 60 miles or so all winter then as soon as the ethanol was taken out of our gas BAM not a single code for either of us since JAN 31st when it was gone. that's just my experience but could the ethanol be causing the engine to vibrate differently harmonically? does anyone have regular gas that is throughing the code? I live in nevada so we have 91 oct and they add ethanol in the winter to keep it from freezing.
Old Mar 24, 2005 | 09:37 AM
  #435
MYFIRSTEVO's Avatar
cool man. thanks
