Random Misfire 0300: Dealership reflash available...
Old Apr 7, 2005 | 09:35 AM
  #451
Option2's Avatar
Originally Posted by dude
Just got my first P0300 after getting Crower cams installed. 15000 miles and previously nothing on a Vishnu stage 1.
I don't misfire at all, and it only seems to trigger the light at idle. Since the only thing that changed was the cams, I'm assuming they made the sensor go off. I'm back in Korea now, but when I get back I'll see if the Xede V3 firmware might help.
Same thing with me. After I had cams installed, i started getting the P0300 CEL. Mine is also triggered at idle. Someone on the NorcalEVO board has the latest flash from
and seems to be doing the trick.
Old Apr 26, 2005 | 01:03 PM
  #452
MrMejia's Avatar
yup, I have a bone stock evo with 32k on it and I just got the flash done and it seems to be holding up perfectly fine. even idles better than before. all I have is an exedy hyper carbon single with flywheel and a drop in K&N.
Old Apr 26, 2005 | 01:05 PM
  #453
webguy330i's Avatar
that's not exactly bone stock but glad to hear it's working for you (the flash).
Old Apr 26, 2005 | 01:13 PM
  #454
MrMejia's Avatar
ooops.....I guess your right webguy . what I meant to say was that its bone stock "emmisions wise" . aww well, whateva.
Old May 17, 2005 | 07:26 PM
  #455
nine4surfah's Avatar
My first p0300 cel occured on april, I took it to mitsu and had the reflash. Unfortunately on my way to work today the damn CEL lit......P0300 again, after the Mitsu reflash!!!!! has this happpend to anyone else after a Mitsu reflash?
Old May 17, 2005 | 08:06 PM
  #456
awdjunkies's Avatar
Any of you experience power loss after this reflash ???
Old May 17, 2005 | 10:37 PM
  #457
infiniti99's Avatar
I noticed a power gain after reflash, and yes I still get the CEL
Old May 18, 2005 | 03:43 AM
  #458
modvp's Avatar
Sorry, I may have missed this while doing a search. How do the P0300 codes affect the cars’ ability to pass emissions? Will it receive an automatic failure?
Old May 18, 2005 | 08:18 AM
  #459
KazzEvo8's Avatar
Now you're at the crux of why Mitsu might need to be responsible here. An irrepairable problem with emissions will get you federal attention damned quick. It will extend beyond the powertrain warranty.
I've heard that often when this occurs the car will act like it's running on fewer cylinders, stumbling, etc. I have this problem and the symptoms seem consistent with this. If that's the case there's some gas not being burned I'd believe so, yes, emissions MAY be a big issue...
Old May 18, 2005 | 12:45 PM
  #460
webguy330i's Avatar
Yeup!! Not to mention you can't pass smog in Cali with a freakin CEL now can you?
nine4surfah, that is essentially the issue now, because thus far no reflash offered by Mitsu has fixed this problem 100%. It may lessen it, or it may hide it better, but the problem is still there.
Old May 18, 2005 | 06:18 PM
  #461
evo_will's Avatar
My Evo triggered the P0300 twice in a total of 76k miles; just got the latest flash from Mistu and now I get the CEL too much. I either have to drive my car slower than 80mph or faster than 90mph to not tirgger the code. what a pain!
Old May 18, 2005 | 07:17 PM
  #462
webguy330i's Avatar
Now that is a horrible situation. I'm sorry mang. =/ ****ing bastards.
Old Jun 24, 2005 | 09:11 AM
  #463
naucrx's Avatar
Bahahah!! I knew it wouldn't hold up!! I got the ECU flash ~20k miles ago, and a new tranny ~11k miles ago that was supposedly going to "fix" my P0300. But nope. Yesterday driving on the highway I got it again. Stupid . Looks like it's time for an EMS now.
Old Jun 24, 2005 | 09:13 AM
  #464
webguy330i's Avatar
Pretty much the only solution, good luck!
Old Jun 24, 2005 | 09:29 AM
  #465
jj_008's Avatar
Vishnu is selling the CReader OB2 scanner which suppresses the P0300 code from happening. Apparently, you just plug it in and stuff it under the dash. It's a pretty small unit. You may want to check it out.
