Random Misfire 0300: Dealership reflash available...
Old Jun 27, 2005 | 03:13 PM
  #481
webguy330i's Avatar
Originally Posted by Option2
Unfortunately the CReader stays on even if you take the key out of the ignition. I don't know how much of a drain it would put on the battery. I'm assuming as much as a car alarm would?
For bonus points, hook into the switched power of the cig lighter.
Old Jun 27, 2005 | 08:43 PM
  #482
Option2's Avatar
Originally Posted by Ted B
None. AFAIK, the OBDII port is activated in the key 'ON' position.
That's weird becuause when I plug the CReader into the OBDII port with the ignition off, the CReader does its countdown like it's attempting to read a code.
Sorry..didn't mean to hijack the thread...back to the regularly scheduled program.......
Old Jun 30, 2005 | 08:29 AM
  #483
highmileage's Avatar
Just got my car back from the dealer. So far for the P0300:
1) Six ECM reflashes
2) New ECM
3) New transmission, clutch flywheel and disc
We'll see if #3 works.
Old Jul 1, 2005 | 06:06 PM
  #484
dibbage's Avatar
Did Mitsu do this at no charge?
Old Jul 5, 2005 | 10:37 AM
  #485
webguy330i's Avatar
2) New ECM
Do keep us posted bro!
Old Jul 6, 2005 | 08:07 PM
  #486
MitsuJoe's Avatar
I am really too lazy to read through 25 pages of this.
Will this dealer flash overwrite a dynoflash/turbotrix flash?
If it does is the ECU reflashable after the dealer flashes it?
I was told the delaer flash would not overwrite a tune flash although it sure would be nice to know!
Old Jul 6, 2005 | 08:49 PM
  #487
Jamie@WORKS's Avatar
Yes, a dealer flash will overwrite any other that's on the ECU. I can't speak for the others, but WORKS has the appropriate Brain Flash that blends seamlessly with all of the Mitsu reflashes.
Old Jul 6, 2005 | 08:54 PM
  #488
MitsuJoe's Avatar
Well I also have a thread in the Turbotrix area of the forum. My understanding though is that the part that deals with the tune and the part that deals with the code are two seperate parts of the ECU. This means it will go untouched. I guess I should go drive it hard and find out.
Works: Are you able to reflash the ECU after a dealer flash?
Old Jul 6, 2005 | 08:59 PM
  #489
Yes, we have reflashed a number of ECUs after both versions of the Mitsu P0300 reflash.
Old Jul 6, 2005 | 09:03 PM
  #490
MitsuJoe's Avatar
WORKS,
Are you a ECUTek reflash dealer?
Old Jul 6, 2005 | 09:04 PM
  #491
MitsuJoe's Avatar
WORKS,
Old Jul 6, 2005 | 09:17 PM
  #492
WORKS,
Of course
Old Jul 6, 2005 | 09:28 PM
  #493
MitsuJoe's Avatar
Well in that case I see no reason why TT or Dynoflash would overwrite the ECU's on a flash because they are also ECUtek dealers.
Although if a dealer flashes over a ECU after you have flashed it will you guys have to flash it again to bring back the tune? I am looking for a catch22 here although if I need a reflash for tuning purposes and WORKS is the only company that can guarantee not to kill my ECU it may be worth the extra investment. Do you guys tune for mods that are not yours? Do you tune based from knock? What is your AFR ratio for a typical mail tune?
Thanks!
Old Aug 23, 2005 | 06:55 PM
  #494
SEEYA's Avatar
just to clarify, do you have to have a CEL in order to throw this code?
Old Aug 23, 2005 | 09:38 PM
  #495
MitsuJoe's Avatar
Yes it seems like you do.
