shifting problems
Old Jul 15, 2004 | 01:43 PM
smokymtsguy's Avatar
Thanks for the feedback. I called the dealer, talked to the service manager. He said it definately shouldn't be doing that and for me to bring it in and he would check it out. Figured I'd give them a chance. I'm taking it in next week and will let you know what happens.
Old Jul 21, 2004 | 03:17 PM
Ok,I took it in to the dealer. They had two different techs drive it (without me in the car). One said he couldin't get it to grind, one said it only happened when he power shifted. I asked for someone to ride with me. Well, a third tech drove it with me in it, he shifted it slowly and no problem. I drove it, shifted it quickly, but lifting, not power shifting and it grinded. He said I needed to lift a little more until the car was broken in better allowing the clearances time to increase, about another 2000 miles and he believed it would then not grind. Also, he said this was how he shifted his car at the drag strip, not power shifting. I asked his opinion about syn fluid for the trans, he said he would definately recommend BG Snycroshift but only after about another 2000 miles. I'm going to try that and see what happens.
Old Jul 22, 2004 | 06:02 AM
evo8nj's Avatar
thanks for the post..
i'm switching from synthetic to BG as well very soon.
Old Jul 22, 2004 | 10:36 AM
Mr_Green's Avatar
its happened to me before two and made a wonderful grinding sound. i found that the pressin the clutch down all the way really helps, but then again the evo is my first stick so it could be me
Old Jul 22, 2004 | 10:57 AM
gnulooks's Avatar
I had the same problem. Solved it with a Stainless Steel clutch line, shifter bushings, underhood shifter bushings, and I removed the clutch resistor pill. Also, the BG syncro is the best stuff for the tranny. I no longer have second gear grinds and the shifter now feels like butter.
Also, this forum might help you out: https://www.evolutionm.net/forums/sh...gear+gringding
Old Jul 25, 2004 | 01:38 AM
trinydex's Avatar
i missed second a couple times, stock shifter is pretty sticky cuz of the rubber bushings, get brass shift cable bushings and a shift kit htat has metal shifter base bushings, change yer tranny fluid ect. should make for quicker more smooth shifts.
Old Jul 25, 2004 | 01:44 AM
NvsEvo's Avatar
sorry if it was already mentioned, but what is the best type of tranny fluid? and would i be able to change the bushings myself?....
Old Jul 25, 2004 | 01:57 AM
trinydex's Avatar
all shift related bushings you can replace yourself, people on these boards tend to favor redline, i've heard royal purple yields hp increase (so does redline), so whichever you hear less horror stories from haha.
Old Jul 25, 2004 | 01:58 AM
Sentinal's Avatar
That reminds me I need to change mine out I haven't done that yet.... I know shame on me
RomansEVO8
25
Sep 16, 2008 06:22 AM
RomansEVO8
10
Aug 29, 2008 08:54 PM
nicknac
Mar 13, 2008 11:39 AM
72Tornado
Jun 22, 2007 11:00 AM
bluebanana23
Nov 2, 2004 06:04 PM
